#52270 by showphone
Wed Feb 23, 2011 4:47 pm
None of the suggestions for successfully using the Firefox 02c plugin worked, so I contacted Dr. Klaus Kremer at o2c. He sent me the following html code and it works great for both Firefox and IE. His code is red, I spliced in the rest of the code to get notification of the controls I wanted:
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<BODY
BGCOLOR="#000000" TEXT="#000000" LINK="#0000FF" VLINK="#800080" ALINK="#0F0000">
<div align="center">
<table border="0" cellpadding="4" cellspacing="4" style="border-collapse: collapse" width="100%" height="100%">
<tr>
<td width="100%" align="center" height="100%">
<p align="center" style="margin-top: 0; margin-bottom: 0">
<font face="Verdana, Arial" size="1" color="#FFFFFF">Shift+left button for Pan,
Ctrl+left button for Zoom, Right Click for settings.</font><br><br>
<script type="text/javascript"
src="http://www.o2c.de/utilities/o2c-utils.js"></script>
<script type="text/javascript">
o2cInsertObject('o2c_id1', '2.0.0.57', 640, 480,
'Phi="227.864700"; ' +
'Psi="39.359985"; ' +
'Zoom="0.903993"; ' +
'PanX="-0.224418"; ' +
'PanY="1.685330"; ' +
'ObjectURL="cubeSmith.o2c"');
</script>
</body></html>
Change the ObjectURL to your Object of course and to your location if not in the same folder.
He gave me a good tip on getting the desired opening appearance of your Object. Play your object by clicking on it's o2c file. Adjust it too how you want it with the spin, pan and zoom controls. Right click it and you will see that particular html is copied to the clipboard. Copy and paste the generated Phi, Psi, Zoom, and Pan information into your html code. Now that position will be the o2c Object starting position.
Long live o2c and DataCAD.
#52271 by joshhuggins
Wed Feb 23, 2011 5:23 pm
Thanks for sharing this good info!
#52273 by showphone
Wed Feb 23, 2011 6:43 pm
Hi Mark,
Using this forum as email to get answers distributed.
What I REALLY like about o2c is that it can be an ActiveX control, so whoever you're presenting to doesn't have to be a DataCAD user or even download the o2c Player. For such a person, when they are prompted to accept the ActiveX or install the plugin, will they therefore get the latest version or could you make sure they get the DataCAD version by putting that version in your code? Because I'd be happy to use a version other than the latest version if it worked better with DataCAD. Thanks.
#52281 by joshhuggins
Fri Feb 25, 2011 12:24 pm
Using the Javascript method seems to not download the file to the users temp files either which is nice if you don't want the user to have access to the file. Is there a way to disable the Right Click, Save Object option? I tried searching for a tag in the Arcon forums but I couldn't get a good translation going.
#52286 by joshhuggins
Fri Feb 25, 2011 3:08 pm
Awesome Mark, thanks! I didn't know that page was there. Wonder what other treasures I'm missin? Might want to sticky a post in the O2C area with the link for future use.
#52291 by showphone
Fri Feb 25, 2011 5:37 pm
In order to test if the DataCAD version with ray tracing would be used if that particular version of the o2c player was referenced in the html, I changed the html to that particular version (1.9.9.149), uninstalled the o2c plugin (2.0.0.56) from Firefox and accessed the revised html. Firefox installed the newer plugin.
So it seems to me that there's no way to use Firefox with the older version of the plugin, therefore ray tracing in Firefox is not possible. Does anybody else see it differently? Thanks.
#52293 by showphone
Fri Feb 25, 2011 5:51 pm
Ok, so I think I should put some directions in my html along with my control directions about pan and zoom that says "note, light and shadow effects can only be viewed using IE". Would that be a good way to go?
#52294 by joshhuggins
Fri Feb 25, 2011 6:27 pm
I think your right.
Users browsing this forum: No registered users and 26 guests
