#4761 by dmooney
Fri Jul 29, 2005 2:18 pm
I have to flip a plan 180 degrees and now have to adjust all the text. Is there a way to edit the text angle attribute? or is there a macro that will rotate all the text 180 around each entities center?
Not looking foward to having to rotate or move every piece of text individually.
#5045 by dmooney
Wed Aug 10, 2005 9:41 am
The double mirror worked great for the single line room labels. Had to move text around for labels with 2 or more lines (not to many).
If any one else use this trick make sure you mirror a reference point along with the text so that you can easily move the text to the correct location.
#5604 by dmooney
Wed Aug 31, 2005 9:48 am
We use the Precision Fonts ArchTXT font and have always worked around its odd quirk of not justifying correctly. Recently it has become a hassle, and I was wondering wether the author of these fonts may have corrected the issue.
(The technical problem is that some characters are read by DC as having a width of zero)
Users browsing this forum: Google [Bot] and 69 guests
