Mark F. Madura wrote:...If you go to the View pull-down menu and render by layer (embedded material definitions) versus by layer (external DMF file), then launch the Object Viewer, the DataCAD version should look similar to the original o2c file.
This is a huge improvement on o2c objects handling. Really Great!
Note: We cannot query the scale of a given bitmap texture from an o2c object so you'll have to reset them manually.
The original object was modeled with the slabs in horizontal position, but when inserted on the roof it was on a slope. The textures went skewed something.
I hope to be possible in the future, allow changes in the texture direction for o2c, like wished in the item:
http://www.datacad.com/bbs/viewtopic.php?t=1530
Miguel
