Hello Roger,
There is no difference between importing and opening a DWG. What do the notes identify as? Maybe they are MText? So, try using Change/Text/Contents.
Hi Roger,
Did you try to open the symbol in the Symbol Editor? You can Control-Right Click on it, and select Edit Symbol, or set up the Program Preferences to open the SE by double-clicking on it.
Hi Roger,
You're welcome -- I'm glad I could help.
Thanx Neil,
I have been fighting this issue for several years now. You have no idea how many tens of hours I have spent tracing over those symbols so I could edit them.
Now for the next step: Some of my drawings have up to a dozen symbols that I want to explode, first to a polyline then to lines and arcs. So far I have visited each one and performed the explode step for each then convert them to lines and arcs using the area command.
Is there a way I can explode them all in one step?
Joe
Still on v. 12
Joe
Still on v. 12
Neil Blanchard wrote:Is there a way I can explode them all in one step?Have you tried the 3dMenu/Explode/SymExplode command.
It might not get the polylines, but should turn all into individual entities, (lines, arcs, ellipses) etc.
joeferguson wrote:Is there a way I can explode them all in one step?
If you have the macro 3DTools, there is a "Kaboom!" command, yes that's the name and it explodes everything back to an entity based on some setttings.
Tried 3dMenu/Explode/Symexplode and it returns the message "The exploded entity is a symbol" but no explosion.
Don't think I have the Kaboom tool. Never seen it in 7 years. How does one get it?
joe
joe
I forget where I got the macro 3dTools from. It looks like it came from Madura studios, maybe it came with the program????
Try Evan Shu's Cheap Tricks Ware - CheapTricksWare.com
James Goodman, AIA
Capistrano Beach, CA
Since V2.5f (1985)
Since V2.5f (1985)
rogerra wrote:I just opened an autocad drawing in Datacad v12.
There are note symbols that I can't seem to explode so that I can edit them.
I would suspect that, in typical Autocad fashion, that these symbols are nested n-levels deep. The Explode command in the 3D Edit menu only explodes 1 level at a time. Using that function, you would need to Explode the symbol "n" times until it is broken down into its base entities.
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
