Can anyone please help me with manipulating views in sunshader. When I rotate a view the view seems to rotate about the centre of the extents of the model. This can often mean what I am looking at disappears off the screen. What I am trying to do is to rotate the view about the centre of what is displayed. I am trying to move about in a similar fashion to Sketchup. Is this possible?
Walter DataCAD user since V3.6E DataCAD V18 subscriber
Since the Sun Shader does not currently provide a way to change your viewing center, you have to pan the view after rotating it.
So, rotate to the side of your model you want to look at, then use [Shift] + Left-click to drag the area of your model you want centered on the screen.
