I cannot render by colour in Sunshader in V16
I don't use Sunshader much but I'm sure I have been able to do this before.
I can use o2c materials setting render by colour or render by layer, usually the former and normally not much difference. This works fine in V16, but I thought the same logic translated to Sunshader.
I have the same problem in V15.04.01.07, but I don't know if this is because I have the same version of Sunshader therein.
This problem arises because I have the entire building on one layer.
Edit 1
I have just activated an older version of V15 on a laptop and Sunshader works OK rendering by colour.
Edit 2
I can work round this problem by changing the layer colours back in DataCad. This matter arose because a subject building was the same colour as an adjoining wall. This was a coincidence, and not normally a problem. It can be fixed by changing the layer colour of the latter, irrespective of the entity colour.
I must say that that little layer manager is useful bit of kit........
Edit 1
Edit 2
Nick Pyner
Dee Why Beach NSW
Dee Why Beach NSW
