When I turn my clip cube on to isolate the elevation, some of the layers inside the clip cube are turned off. What am I doing wrong?
do have "Ignore Z" on, otherwise you might be clipping off at a certain z-height.
No I have ignore Z off.
I did copy lines from one elevation to another and now I am an trying to clip the two elevations and that is when the problem occurs.
Try it with Ignore Z on and see if that helps.
Users browsing this forum: No registered users and 60 guests
