Hello DataCAD Pro's,
How would I align an object with another in DataCAD? For example, if I had a roof line drawn and wanted to align a row of roofing tile at the same angle, how would I go about doing so?
In AutoCAD I used to use an align command, select the line and voila, it would align the desired object exactly to the one selected. Is that possible to do in Datacad too?
Thanks in advance for your help,
CADwk
CADwk
