#66299 by cblair
Fri Apr 24, 2015 1:42 pm
I am in receipt of some SAVE AS files from Vectorworks: DWG and DXF from each of the above releases. When importing into a empty AEC file (17.02.00.09 SE) in Windows 7 DataCAD closes after a few seconds of importing. I wonder if there are tricks or tips from anyone that I may employ. While trolling this board it seemed that perhaps I should try importing directly from the VW file without using the SAVE AS..... I will try that.
#66300 by MtnArch
Fri Apr 24, 2015 5:20 pm
You might try running the DWG/DXF through AutoDesk's DWG TrueView and save it back out before importing it into Dcad.
#66308 by MtnArch
Mon Apr 27, 2015 5:27 pm
There are other Acad clones that you could try as well, but most (if not all) of them require payment - but I don't believe DWG TrueView costs anything.
Good luck!
Users browsing this forum: No registered users and 9 guests
