Hi,
I just noticed that the Update GTV button in the Layer Manager doesn't work with the GTV Link. I already had GTV Link toggled on, and when I toggled on the XRef layer, and change the layers that er on in the RFM, and then Update the GTV using the LM button, it doesn't work. If I use the GTV menu Update View button, it does work.
