#66375 by Neil Blanchard
Fri May 08, 2015 8:04 am
Okay, I am still having issues with the Symbol Scale settings. I had Symbol Scale By Folder (SBbF from here on) on, and the Symbol Scale is toggled on. If I turn off SBbF, then the Symbol Scale still shows as checked on, but is grayed out.
Why can't I toggle of Symbol Scale off after I toggle off SBbF?
#66376 by joshhuggins
Fri May 08, 2015 12:18 pm
Once Symbol Scale is turned off in the symbol browser, then you only toggle it on/off via the Datacad menu. The menu should remember it's last state.
Think of the SSBF toggle as a switch of where Datacad is going to look for the Symbol Scale value.
If SSBF = ON: Datacad looks via the symbol browser at the current folders symbolbrowser.ini file, reporting it's state back shown by the Symbol Scale toggle button which is only available to toggle when SSBF is turned on.
If SSBF = Off: Datacad looks at the Datacad menu for the last remembered state of Symbol Scale remembered in the Dcadwin.ini file. It ignores any settings set in the Symbol Browser related to symbol scale being on or off.
#66431 by Neil Blanchard
Mon May 18, 2015 3:02 pm
I am apparently unable to object snap on a symbol in the SB to get a custom insertion point. I will restart, and see if I can get it to work.
Edit: nope - a reboot didn't help. Why can't I snap to a symbol in the Symbol Browser?
Edit 2: I had By Center toggled on - which is something I didn't even know existed until now. Toggle it off, and then custom insertion points are possible.
Users browsing this forum: No registered users and 73 guests
