Anyone have a favorite PDF to JPG converter they can recommend, freeware preferred?
PDFFill.com, the PDFFill Tools has that option.
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
Tracker PDF XChange user here too, using the newer XChange Editor which is kind of the next version of the viewer with more features for free. It's still free, but has a pay option for some premium features, which are worth the upgrade if you spend much time working with PDF's. Everyone should give it a serious try, it's really powerful and well built. http://www.tracker-software.com/product ... nge-editor.
missed the export feature in pdf-exhange viewer, learned something new every day from this wealth of knowledge.
Much thanks guys, as usual I'll go with the DataCad CTO's suggestion first.
Stuart Jackson wrote:Much thanks guys, as usual I'll go with the DataCad CTO's suggestion first.
Okay, but if it doesn't live up to your expectations can we blame it on Josh instead of me?
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
David A. Giesselman wrote:Stuart Jackson wrote:Much thanks guys, as usual I'll go with the DataCad CTO's suggestion first.
The youth these day's.... Always looking for someone to blame
"Life isn't about dawdling to the grave, arriving safely in an attractive, wrinkle free body, but rather an adventure that ends skidding in sideways, champagne in one hand, strawberries in the other, totally worn out, screaming 'yeehaaa, what a ride!"
David A. Giesselman wrote:Okay, but if it doesn't live up to your expectations can we blame it on Josh instead of me?
I purchased a piece of software that converts PDF to DWG. No this isn't free but I found it to pay for itself with one job. It runs $249 for one license. I purchased a double license for $349 so that I would have a copy at my office and at home.
I was skeptical at first but after using it a few times, it really does work. I then easily imported the DWG into DCAD. It is to scale and text comes in as text and not a bunch of pixels put together. I was able to quickly move different lines to the DCAD layers where I wanted them. Way easier and faster than manually inputting the info from a PDF. The only catch is that the PDF has to be a true PDF and not a PDF made from a scanned drawing. Pretty remarkable piece of software. It is on my schedule to do a review of its use and how to get a PDF into DCAD for Cheap Tricks when I get the time. The program is called Print2CAD.
David Porter AIA
(DataCadder since v.2)
[quote="David A. Giesselman"]I use PDF-XChange Viewer. It's free, even for commercial use.
Good call Dave,
Though it's now called PDF-xChange Editor, I downloaded the PRO version and used Export to save as PNG. Great tools, lots of resolution options. Guess I won't be using FoxIt anymore. Thanks again for the recommendation.
Good call Dave,
I'm glad it worked out for you Stuart.
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
The OCR in the this software sounds interesting and they do promise quite a bit. I've found that digitally generated PDF (from CAD or other) are fairly easy to convert to DWG in illustrator. It's the hand drawings that are scanned that give me fits generating a billion pieces of worthless geometry. It's rare to find a hand drawings scanned perfectly "level"...even a degree off throws the whole conversion into a tizzy. Looking forward to your Cheap Trick review.
David Porter wrote:I purchased a piece of software that converts PDF to DWG. No this isn't free but I found it to pay for itself with one job. It runs $249 for one license. I purchased a double license for $349 so that I would have a copy at my office and at home.
Robert Scott
Robert Scott Visualization and Design
Battle Creek, MI
www.scottVIZ.com
Facebook: https://www.facebook.com/scottVIZ/
Flickr link: https://www.flickr.com/photos/scottresi ... ign/albums
RSRD on Vimeo: https://vimeo.com/user31807261
Battle Creek, MI
www.scottVIZ.com
Stuart Jackson wrote:Anyone have a favorite PDF to JPG converter they can recommend, freeware preferred?
Photshop CC...don't leave home without it. $9.99 per month includes Lightroom. You can thank me later
Robert Scott
Battle Creek, MI
www.scottVIZ.com
Battle Creek, MI
www.scottVIZ.com
Users browsing this forum: Majestic-12 [Bot] and 39 guests
