Thanks for the reply Rex, I now realized what I asked for wasn't what I needed to ask.
I did know that the amount the door is open is the angle value, but say the value is set to 0 so the doors are closed the doors are not drawn at 1/2 the opening distance, they are a bit larger so they lap each other still even when fully closed. I guess what I needed to asking for is what determines the door sizes since it's clearly not 1/2 the opening which makes sense since you wouldn't want the door edges right next to each other when closed. I didn't know if it was something we could set, or if there was a standard size that was being used that I may not be aware of. Thanks again.
