Like CLEAN UP #67407 by GARY247 Mon Oct 26, 2015 12:44 pm Is there any way to change the clean up one line trim function so it stays off unless you click F1(entity) to turn it on? I looked in datacad.ini but did not see anything. Username GARY247 Posts 234 Joined Tue May 29, 2007 3:22 pm
Like Re: CLEAN UP #67408 by David A. Giesselman Mon Oct 26, 2015 12:54 pm Look in the [General] section of the INI file for the following key:1LineTrim By Entity=TRUEIf present and TRUE, Entity will always be On.If present and FALSE, Entity will always be Off.If not present, Entity will remember its previous stateDave David A. GiesselmanSenior Vice President & CTODATACAD LLCdave@datacad.comProviding thoughtfully crafted, software bugs to the DataCAD community since 1984. Username David A. Giesselman Rank Chief DataCAD Troglodyte Posts 3880 Joined Thu Feb 10, 2005 4:30 pm Location DATACAD LLC Programming Valhalla Contact
Like Re: CLEAN UP #67410 by GARY247 Mon Oct 26, 2015 1:13 pm Thanks Username GARY247 Posts 234 Joined Tue May 29, 2007 3:22 pm
