I have a drawing where Smart Windows wont insert into all existing smart Walls. I get a message in the command line to insert the first point of the window.
The walls have a height, so that's not a problem.
The windows will insert if I draw a new wall, the same type as the existing walls.
I can insert a Smart Door into the wall ok.
I have purged the drawing and the problem remains.
Does anyone have any suggestions as to what I might be doing wrong?
Copy of the problem file
(60.23 KiB) Downloaded 424 times
Walter
DataCAD user since V3.6E
DataCAD V18 subscriber
