We have a tree symbol imported in from an Autocad drawing that was exploded and saved into a tree symbol file. It was exploded and saved. Now every time the symbol is edited it corrupts the drawing. In the preview what should be colored is turned to black. Even if you dump out of the drawing it is corrupted and does not return to its original state. Once the drawing is corrupted even editing tree symbols made in Datacad do not work correctly. Why is it doing this and how can it be corrected?
Do you still have the original Acad file it came from? I would WBlock it out, open in Acad (or your favorite Acad clone), purge the living snot out of it, then open it as a separate file in Dcad to then save it back out as an AEC file/symbol.
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
Datacad 18 has a repair tool coming out in the near future that should be able to sniff out the bad parts and purge them. Might wait for that if you can and avoid using the symbol in the meantime.
Strange thing is what seems to happen is once this symbol is edited and saved I am no longer able to adjust the density of the color which was possible prior to editing the symbol. It stays the same no matter if it is 100 or 25. I have a road filled with color 126 and I cannot seem to alter the density, only the color of the fill. I tried doing a layer set to see if that would purge the drawing of any crap but it did not work.
On further investigation it seems the tree symbol brought in from another software is affected by a change in scale. It prints in color just fine when printed in a 1:30 scale but the minute you change the scale in Datacad it reverts to all black. Any one have any clues how to fix this?
It sounds like it has some type of "level of detail" attribute within it. Not sure why it would work that way within DC, but stranger things have happened based on the import library.
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
Users browsing this forum: No registered users and 62 guests
