Does anyone know whether Get Snap can be used when drawing slabs. If so what is the trick to getting Get Snap to work. For some reason I cannot get it to work. Get Snap works fine in other situations. Restarting the PC makes no difference.
Walter DataCAD user since V3.6E DataCAD V18 subscriber
Joined
Wed Jul 11, 2007 8:04 am
Location
N.S.W. Australia
It's working here as far as I can tell with X&Y using Rel Cart. Can you take a screen shot of what you were trying to do and where your start point is and what you are trying to snap to with which command?
Do. Or do not. There is no try. Josh's Digital Downloads is come back
online soon. Stay tuned.
(soon is a relative term)
Joined
Fri Feb 11, 2005 5:44 pm
Location
Absolute Zero, California
Thanks Josh I am using Relative Cartesian. In the attached example I am trying to create point D using Get Snap Y at A.
(13.28 KiB) Downloaded 481 times
Joined
Location
N.S.W. Australia
Ahhh gotcha. I don't think it will work snapping to the beginning of the entity you are in the process of creating.
Joined
Location
Users browsing this forum: No registered users and 101 guests
HandCrafted With and By SiteSplat ©SiteSplat 2013
