I work on datacad 12. it has become a problem to import the recent autocad files. I have to get the files backed to 2007 or earlier to get them to import properly. Is there any solution to this problem.
Joined
Wed Feb 10, 2016 9:37 am
The best thing to do would be to upgrade to DataCAD 18; as the DWG import/export is as up to date as possible. If you search this site, you should find a good third party program to possibly save new DWG as older formats.
Joined
Fri Feb 11, 2005 11:24 pm
Location
Maynard, MA, Eaarth
There is a conversion program, believe it is called DWG TrueView, that will backwards convert dwg files.
Robert Parker
Proctor, Vermont, USA
Green grass and high tides forever
Joined
Tue Mar 08, 2005 8:20 pm
Location
Proctor, Vermont
Roger Donaldson AIA CSI CDT NCARB abUsing Datacad since 1986, ver 23.00.02.15 (SE)
http://www .
R ogerD onaldsonA rchitect.com
Joined
Sat Feb 12, 2005 12:33 pm
HandCrafted With and By SiteSplat ©SiteSplat 2013
