#69755 by joshhuggins
Fri Sep 16, 2016 4:52 pm
I am trying to locate the center axis of the red members and need add a vertical 3DLine based on the members ZBase/Height. Right now the easiest way I know how to do this now is to draw a 3DLine in an elevation view with the correct height, then switch to ortho and then copy that 3Dline around. Does that make sense? I was hoping I could just drop a 3DLine in ortho view with my Zbase/height set. Is that possible? If not could we add that to the ol' wish list please?
#69756 by jimgoodman
Fri Sep 16, 2016 5:30 pm
Josh: Set the desired ZBase and ZHeight, Use the Base/Height option in 3d Lines and click twice at the desired location and the vertical 3d line is created.
#69757 by joshhuggins
Fri Sep 16, 2016 6:01 pm
A related wish, would be could we get an option in the 3D entity creation menus for inputting at the height between the zbase/height? Maybe call it Center Z?
#69761 by Robert Scott
Fri Sep 16, 2016 9:14 pm
Josh and Jim: attend my SoCal 3D seminar in January...I'll show you an easier way to draw a vertical 3D line ;)
Reserve your seats in advance...only two per golf cart!
Bob
#69762 by jimgoodman
Sat Sep 17, 2016 8:46 am
Ah yes, the offsite 3d seminar we've been discussing. I'm not sure why you think Southern California will have nicer weather than Michigan in January, especially this coming year - we are scheduled for our once a decade rain storm in 2017. :roll:
At any rate, I discovered the click-click trick several years ago, by accident. You can also use a short vertical polyline to accomplish the same thing and it's a bit easier to find.
#69763 by Robert Scott
Sat Sep 17, 2016 8:59 am
I don't understand why the Michigan Tourism Board rejected my winter campaing slogans; "Pure Michigan, anywhere but here" and "Michigan, a good place to be from" ;)
Users browsing this forum: No registered users and 80 guests
