#70718 by Neil Blanchard
Fri Jan 27, 2017 9:38 am
The step you may need to do before using the 3D Line Convert, is to change the Z Base and Z Height to 0 for everything. Then when you use the 3D Line Convert, all the 3D line will be converted to 2D lines. The reason is the macro won't convert 3D line that have different Z heights at each end; only 3D lines that are all level at one Z height.
