In DC17 this was not an issue, but now that I upgraded to DC19 it is. Hoping there is an easy fix. [edit - there was. see below]
Issue:
I'm running a dual monitor setup and have the main DC screen on the primary monitor and the symbol browser and layer manager on the secondary.
Except the LM won't stick. It keeps popping back to the center of the primary screen...
doh!
Sometimes you just need to type things out for it to click! Hope this helps someone else out:
SOLUTION:
Tools > Program Preferences > Interface Tab > uncheck "Center Dialog Boxes"
Guess I'll have live with uncentered dialog boxes. Not the end of the world.
Issue:
doh!
SOLUTION:
David L Mooney
