In DataCAD 14, if I clicked on a line or object and hit Alt I, it would change my cursor to the layer, line type, etc. of that line. If I do the same thing in 19, it just takes me to the Identify menu. Is there some way to preform the same function, which was very handy, rather than having to change the layer, then the line type?
Also, the old DCADWIN toolbar had a button to toggle when you wanted to add text. The only way I can see to do this in 19 is to hit Text in the Edit Menu, which isn't the end of the world, I suppose, just different.
