I have a drawing that has and xref in it created in version 18. I created a plot file of this drawing in version 18. The plot file opens fine showing the xref in version 17 and other computers but when I open it on my computer the xref disappears. I tried inserting another xref into the original drawing and then opened up the same plot file in 17 this new xref shows up but when I try to open on my computer in version 18 they don't. I am thinking there there is a program glitch here some where. If I reload 18 do I have the option to do a repair?
Just a WAG - have you checked to make sure that it's not showing up as Orphaned due to a pathing issue? Is the xref on a locked or a layer that has been turned off?
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
Those are not issues as the drawing opens up fine in dcad 17 and other computers in the office. When I go to the original drawing where I have the xref it dumps out if I try to delete it but this happens only when I am using 18 and only on my machine. Do you know if the install as a repair function?
I'm not sure if it has a specific "repair" function (like some do) but you could try a reinstall over the existing. You will need to make sure you de-authorize it FIRST so that you don't run into problems when you reinstall.
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
Hi Gary,
V18 + V19 have the new Repair Tool feature which can be used prior to opening a file.
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
My guess is was a software issue. On top of the xref not showing up the program would dump if I tried to erase or regen the xref. After spending time to try to fix it I gave up and did a repair which (knock on wood) seems to have fixed the issue.
Users browsing this forum: No registered users and 59 guests
