Post off topic threads here.
#71134 by artmanvt2000
Sat Apr 08, 2017 9:49 pm
Hi All,
After years of everyone in our office doing their own thing for saving project electronic files, we have determined it is time to come up with an office standard for continuity from project to project. I hoping people here may be able to give me some suggestion on folder structures that work or resources to industry (architecture) standards for folder structure.
Thanks to all that can help.
Arthur Wood
#71156 by Ted B
Tue Apr 11, 2017 2:14 pm
I have a small one-architect practice, but I used to run the stdio in a larger one years ago. For project files in my current office, I assign a project number and every file for that job goes in the folder or it's sub-folder. The project numbers apply to correspondence, CAD and accounting. The 1st 2-digits are the year, and the 3rd-5th are the sequential project numbers. Subprojects are project-number and it's a/b/c/ suffix; "17432(q.)" -- a new 2017 project, the 432th project # assigned, subproject (q.).
The actual CAD files and Sketchup/Layout files have a file-name hierarchy; minor revisions and "save" files with a a/b/c-suffix. Major revisions or versions get a incremental number 1-2-3-4-, etc... (xxxx) is a project name or descriptive name.
v1 xxxx Architectural files "v1 Plans".
s1 xxxx Site Files
m1 xxxx Sketchup models "m3 Dakota" - the 3rd incremental model for project "Dakota".
p1 xxxx Layout Files.
d1 xxxx Separate detail files.
I have several master project prototype folders listed under "CAD" with sample templates for use based on type, scale, etc... And for sample and prototype details and mfrs. details. The same with typical correspondence, forms, and common reports for re-use or adaptation. The prototype CAD files already have the titleblock-master and sheet layout, the layers, fonts, screen colors for that particular type of drawings; 3/8"-scale detail page, 1/8"-scale residential, 1/16th commercial, 40-ft site plan, etc...
PM xxxxxxx is a project memo
EM xxxxxxx is e-mail in .pdf-format
.Pdf-plots go in a "plots" subfolder, with an optional "date"-subfolder. I initially plot Datacad page by page to. .pdf, then consolidate into one .pdf for that document issue. Individual page .pdfs are sequential; a01, a02a, a02b, a03, etc... The consolidated .pdf file is named by it's date - purpose - and identifier/name; "2017-04-12-Apr Permit Submittal Dakota.pdf"
In a complicated DATACAD project, I might flag each page's layer set-up and position using individual named "save-view"; cs1, a2, s3, e4, p6, e7, d8. Handy for navigating the overall drawing-field, and for correct and reproducible plotting.
All projects are printed using the same saved pen-table and settings on 11x17" paper, and the titleblocks and page-size formatted accordingly. Any plot leaving the office is plotted to .pdf first with the date/purpose identifiers -- then plotted to paper or e-mailed.
I don't use xrefs or self-xrefs often. I recently have found that changing the on-screen xref used for a base-reference to "dotted" linetype creates a handy 50%-screened-effect for a background that snap-able, but unobtrusive in the background on the monitor and on-paper. Experiment varying the spacing and line-weight, depending on the purpose for the desired screened effect.
I use a generous palette of linetypes, pronounced overshoots, and varied line-weights in my pen-table, to plot a hand-drawn "furry" architectural drawings. "Hand-lettered" and "hand-drawn" fonts also help give it an appearance of professional craftsmanship -- versus a cold, neat and sterile CAD drawing.
#71234 by artmanvt2000
Mon Apr 17, 2017 12:46 pm
Thanks for the suggestion. I was looking more for a folder structure that would address all aspect/phases of a project. This would include word documents, pdf's and cad files.
#71235 by Roger D
Mon Apr 17, 2017 12:56 pm
on my data drive I have a directory
Projects
then each year then has a sub directory
then each project has a sub direcotory
then each phase could have a sub directory
Projects
2017
17-01
17-01 Bidding
17-01 CD
17-01 Const Admin
17-01 Photos 170417
17-01 SD
17-01 Specs
etc
Within each sub directory you could have more.
Users browsing this forum: No registered users and 36 guests
