Working on my laptop. Made a bunch of alias commands. Now I want to transfer to my main computer. Looked in the Dcadwin.dca file. None of the new commands show up in it, and the file date is very old. I went back into the program and they are all there and working. Is there something I need to do? Export or save.
What directory (file folder) are you looking in? Should be in Support Files. Your new commands might be at the end of the file, not alphabetical as you might think.
Roger Donaldson AIA CSI CDT NCARB abUsing Datacad since 1986, ver 23.00.01.02 (SE) http://www.RogerDonaldsonArchitect.com
Datacad should not be installed in the Program Files folder anymore (since like v12). Try installing to the Root C:\Datacad 17, I'd bet that fixes things up.
Thanks! - Josh Do. Or do not. There is no try. Josh's Digital Downloads is come back online soon. Stay tuned. (soon is a relative term)
While in datacad, I would double check to see what pathname is listed for support files. I would also do a explorer search for Dcadwin.dca, since the alias are available in datacad, there might be another version of the file elsewhere on the computer.
