Minor wish: it would be great to be able to Change/Text/Toggle Boundary and Set Margins; rather than have to Control-Right Click on each and every ParaText entity.
Just coming to post this very thing - so yes, pretty please???
dcad user since v.5
Hmm ...
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
Thanks Dave!
I just noticed that Change / Match / All does not toggle on Layer - which is on the More ... menu. All the other items on that second menu do get toggled on.
Can Change / Match / All toggle on Layer, please?
Neil Blanchard wrote:I just noticed that Change / Match / All does not toggle on Layer - which is on the More ... menu. All the other items on that second menu do get toggled on.
As Mark stated in the Beta 12 announcement, add the following key to the [General] section of the INI file:
Change Match All Includes Layer=TRUE
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
Thanks, I missed that in the announcement. Mark mentioned it last evening at the DBUG meeting.
Is there a way to set a dimension to be different than the drawing scale type BEFORE you place it? If not, then I would appreciate that tool.
Lock Scale in the Dimension menu allows you to select another scale type.
Here's an extension of how Free Trim works: if we could instead of erasing a line segment between two intersections - if the segment we select could be changed to a different linetype, instead - that would be great.
Neil Blanchard wrote:Here's an extension of how Free Trim works: if we could instead of erasing a line segment between two intersections - if the segment we select could be changed to a different linetype, instead - that would be great.Would love this with Free Trim! Great idea Neil!
Thanks! - Josh
Two wishes - one small, and one big:
It would be good to be able to toggle on "Ignore CC's" before inserting a symbol.
It would be AMAZING if a 3D Clip Cube could apply only to SOME of the layers that are on at a given moment, and not to other layers. This would be like having a self reference with an X-Clip Cube, without having to set up the self reference.
Can we have a Bisect option in the Mirror menu, please? This would save having to use the Bisect in Tangents.
Neil Blanchard wrote:Can we have a Bisect option in the Mirror menu, please? This would save having to use the Bisect in Tangents.Good wish!
Thanks! - Josh
Done for the next Subscription update.
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
Users browsing this forum: No registered users and 29 guests
