#72312 by Roger D
Sat Sep 16, 2017 11:46 am
double check your .ini settings for bitmaps
[Printer]
Enhanced Bitmap=True
Print Bitmaps=TRUE
#72316 by joshhuggins
Sat Sep 16, 2017 11:23 pm
Also sometimes if the image is too large it won't print using the built in PDF creator, so we use a 3rd part PDF print driver like PDF XChange to print PDF's. Also if you are inserting actual .BMP files, try saving the images to a different format like .PNG or .JPG and inserting that file instead as they should be much smaller.
Users browsing this forum: No registered users and 127 guests
