#72352 by artmanvt2000
Wed Sep 20, 2017 4:03 pm
[General]
1LineTrim By Entity=TRUE
2D Mirror By Entity=
ABNT=FALSE
AllCaps Linked=FALSE
Allow Scale Dependent Nested Symbols=FALSE
AndCopyRemembersStatus=TRUE
Auto Extract 2D Symbol=TRUE
Auto Extract 2D=TRUE
Auto Extract 3D Symbol=FALSE
Auto Extract 3D=FALSE
Auto Fence=FALSE
Automatic Crossing Selection=FALSE
Automatically Group Dimensions=TRUE
Autosave Interval=15
Busy Cursor=aero_busy.ani
CapsLock=FALSE
CAVWALL=FALSE
CenterDialogBoxes=FALSE
Change Match All Includes Layer=FALSE
CHECK_SYM=FALSE
CLIPCUBE_DISPLAY=TRUE
Close Symbol Editor Windows First=TRUE
Color Menu Goes Directly To Dialog=FALSE
CommaKeyErasesLastEntity=TRUE
Compressed Drawing Files=TRUE
CoplanarCheck=FALSE
Copy Keeps Groups=FALSE
Create Session Files=TRUE
CTRL_SCROLL_WHEEL_ZOOM=FALSE
Default Input Mode=
DEFAULT_DRAWING_NAME=DC19_DFLT.AEC
DEL_DUP_ATTRIBS=TRUE
DelDupLyrAttribs=TRUE
Detail Highlight=TRUE
DinStdNoBump=FALSE
Disable Line Weight Hot Key=FALSE
Do Not Rotate Dimension Text=FALSE
Double Click For Properties=TRUE
Double Click For RFM=TRUE
Double Click For Symbol Editor=TRUE
Draw Ellipse As Arc=TRUE
Drawing Sessions=10
Duplicate Symbol Attributes Fix=TRUE
EditForceTo2D=TRUE
EditForceTo3D=TRUE
Entity Context Menu Obeys Layer Search=FALSE
Excel Uses Drawing Font=FALSE
Exit LockSize On Selection=FALSE
Explode Keeps Groups=FALSE
Fix Text Matrix=FALSE
FIX_DIMS=FALSE
FixFont=FALSE
FixMSPDetails=TRUE
FONTNAME_TTF=ARIAL
FONTNAME=ARCQUICH
GTV Remembers Tangents=TRUE
HYPERVIEW=ALT
Insert Key Disabled=FALSE
Layer Menu Remembers Position=TRUE
LayerColorRemembersStatus=TRUE
Left+Right Mouse Button Panning=TRUE
Logging=1
Logical Pen Width Adjustment=0
Logical Pen Width=TRUE
Max Freezoom Screen Percentage=95
Meters Show Leading Zero=TRUE
MinusKeyTogglesOvershoot=TRUE
MultiRemembersStatus=TRUE
New 3D Menus=FALSE
New Crossing Fence=TRUE
New Dimension Visible Attribute Positioning=FALSE
New DimTxtPnt Calculation=TRUE
New FreeTrim=FALSE
New Regen=TRUE
New Smart Object Generation=TRUE
New Text Scale=TRUE
NewSymbolExtents=TRUE
No Command Line in Layer Menus=FALSE
No LockSize=FALSE
No Macros From Locked Layer=FALSE
No Scroll Keys=FALSE
No Text Scale=FALSE
No Timer Pause=FALSE
NoGridInSelect=TRUE
Old File Dialogs=FALSE
Old Line Weights=FALSE
OldHelp=FALSE
OpenNewer=TRUE
PeriodKeyRestoresLastEntity=TRUE
Perpendicular Snap to Text=TRUE
PKeyRememberFreeZoom=TRUE
PKeyRememberPanScroll=FALSE
Prevent Windows Screen Saver=FALSE
Prevent Windows Sleep=FALSE
PurgeDrawingsOnExit=1
Reload Nested Symbols=FALSE
Reverse Scroll Wheel Zoom=FALSE
Save Current Plot Scale With View=FALSE
SaveAs Uses Current Drawing Folder=FALSE
Scroll Keys in Layer Menus=FALSE
Select All Character=A
SHADER_SAVE_PROMPT=FALSE
Shift For Implied Deselect=FALSE
Shift For Implied Match=FALSE
Shortcut Keys Invoke Alias=FALSE
Show Absolute Zero=TRUE
Show Current Reference Point=FALSE
Show Hatch During Drag=FALSE
Show Object Snap Point=FALSE
Show PText/MText Boundary On Entry/Resize=TRUE
Show Visible Attributes When Dragging=FALSE
ShowWinCursor=FALSE
SHX Conversion=100
Snap Clipping=TRUE
Spacebar For Distance Input=FALSE
SSRebuildType=Check
Superscripted Areas and Volumes=TRUE
Suppress Witness Line 1=TRUE
Symbol Attribute AllCaps=FALSE
SymbolCacheSize=2
TXTSCALE=TRUE
Use Significant Digits In Dialogs=FALSE
USE_DFLT_DWG=TRUE
USER_COMPANY=EHDanson Associates, PLLC
USER_NAME=CAD1
[Paths]
INSTALL_DIR=C:\DataCAD 19\
PATH_BMP=Support Files\Toolbars\
PATH_CLIPBOARDFILES=Clipbooks\
PATH_DATABASES=Databases\
PATH_DCRENDER=RAY\
PATH_DEFAULT_DWG=Default Drawings\
PATH_DEFAULTS=Support Files\Program Defaults\
PATH_DIMSTYLES=Support Files\Dimension Styles\
PATH_DOORTYPES=Support Files\Door Types\
PATH_DRAWING=P:\UNION BANK - MORRISVILLE\DRAWINGS\EHD CAD FILES\DEVELOPMENT\
PATH_DXF=P:\UNION BANK - MORRISVILLE\DRAWINGS\PEARSON\SENT-2017-09-11-PROGRESS\
PATH_EXCELFILES=Excel\
PATH_FONT=Fonts\
PATH_FORMS=Report Forms\
PATH_GUI_FILES=Support Files\
PATH_HATCHPATTERNS=Support Files\Hatch Patterns\
PATH_HELP=Help\
PATH_INSERTMETAFILE=Metafiles\
PATH_LAYER=Layer Files\
PATH_LAYOUT=Layout\
PATH_LINETYPES=Support Files\Line Types\
PATH_MACROS=MACROS\
PATH_MESSAGES_LABELS_MENU=Support Files\Messages and Labels\
PATH_O2C_MAT=Materials\
PATH_O2C_TEX=TEXTURES\
PATH_O2C=o2c Objects\
PATH_O2CMATERIALBASEPATH=Materials\
PATH_O2CTEXTUREBASEPATH=Textures\
PATH_OUTPUT=Plot Files\
PATH_PALETTES=Support Files\Color Palettes\
PATH_PENTABLE=SUPPORT FILES\PEN TABLES\
PATH_PLOTTERSETTINGSPATH=Support Files\Plotter Settings\
PATH_RECOVERY=RECOVER_ARCHIVE\
PATH_SAVEASPDF=P:\RESIDENTIAL PROJECTS - SINGLE FAMILY\BRADLEY RESIDENCE\FIELD SKETCHES\
PATH_SESSIONS=Session Backups\
PATH_SHADER=P:\UNION BANK - MORRISVILLE\PRODUCT RESEARCH\ARCA CASH RECYCLER\
PATH_SKETCHUP=P:\UNION BANK - MORRISVILLE\EHD CAD FILES\SCHEMATICS\SCHEME A\
PATH_SMARTDOORSYMBOLPATH=Symbols\
PATH_SMARTWINDOWSYMBOLPATH=Symbols\
PATH_SPELLCHECK=Support Files\Dictionaries\
PATH_SUN_SHADER=Sun Shader\
PATH_SUPPORT=Support Files\
PATH_SWAP=Temporary Files\
PATH_SYM_INSERT=T:\
PATH_SYMBOL=T:\
PATH_SYMBOLBASEPATH=T:\
PATH_TEMP=Temporary Files\
PATH_TEMPLATE=Templates\
PATH_TXTSTYLES=Support Files\Text Styles\
PATH_TYPESBASEPATH=Support Files\
PATH_WALLTYPES=Support Files\Wall Types\
PATH_WINDOWTYPES=Support Files\Window Types\
PATH_XREF=P:\UNION BANK - MORRISVILLE\DRAWINGS\EHD CAD FILES\DEVELOPMENT\
PATH_XREFBASEPATH=P:\
Session Files Live With Drawing=FALSE
[Alias]
Popup Lines=8
Popup Width=512
[Audit]
Entity 2D Flatten=FALSE
Entity Invalid=TRUE
Extraordinary Values=TRUE
Polyline Duplicate Vertices=TRUE
Regen On Load=TRUE
SWOTHLUDFBK Off=FALSE
Symbol Entity Invalid=TRUE
[BackGroundColor]
DrawingAreaColor=0 0 0
QuickShaderColor=153 204 204
[Bitmaps]
MaxSize=100
MinSize=0.001
[Classic Interface]
Navigation=FALSE
Projection=FALSE
Status=FALSE
[Clipboard]
CopyBitmap=TRUE
CopyInColor=TRUE
FileName=
MaxClips=10
MultiStroke=TRUE
Paste Keeps Groups=TRUE
PenWidthFactor=10
[Custom Settings]
Default Door Type=
Default Wall Type=
Default Window Type=
[DC Render]
Materials=LYRCLR
[DEBUG]
Draw Text Insertion Point=FALSE
DWGSplineAsPoint=FALSE
LabelFileEditor=FALSE
ShowUndoHistory=FALSE
Write Symbol=FALSE
[Dialogs]
Adjust Item List Height=TRUE
Item List Height Adjustment=0
[Display]
Enhanced Bitmap=FALSE
Max Entities=10000
Max Vectors=15000
[Display List]
DoublePrecision=TRUE
Min Arc Vectors=24
UseBoxOnScroll=TRUE
UseSetPixel=TRUE
[DrawingArea]
FONTNAME=Arial
POINT_SIZE=10
STYLE=Regular
[DropMesh]
MaxDivisions=100
[DXF_DWG]
Adjust Text Sizing=FALSE
BackwardTextFlag=TRUE
Bind XRefs to Symbols=TRUE
Custom Lines=TRUE
Explode 3D=FALSE
Flatten All Entities=FALSE
Interactive=TRUE
KnockOut Borders On=
Last Export=3
Merge Symbol Layers=FALSE
Process XREFs=TRUE
PROCESS_PAPERSPACE=FALSE
Self Xrefs Only=FALSE
Settings File=TRANSFER.INI
TBL File=FALSE
ToAbsZero=FALSE
Try R12 Conversion=TRUE
Try R14 Conversion=TRUE
Validate Entities On Import=TRUE
XRef Export=FALSE
[External Types]
Doors=TRUE
Walls=TRUE
Windows=TRUE
[File Dialog]
Drawing Preview=TRUE
Extension=PNG
Last View=Details
o2c Preview=FALSE
Preview Forced Save=FALSE
Preview=FALSE
[Hatch/Linetype Preview]
Size=300
[HatchPatterns]
Converted=TRUE
Scale to View=TRUE
ShowExternal=TRUE
SingleClick=TRUE
[Hints]
Color=251 233 167
Delay=100
Dynamic Snap Delay=200
Dynamic Snap Hide Delay=2400
Dynamic Snap Hint=TRUE
Dynamic Snap Type=1
Dynamic Snap=TRUE
Hide Delay=2400
Inference Snapping=FALSE
[ImageQuality]
HighJPEGQuality=90
HighJPEGSmooth=90
HighPNGInterlace=FALSE
HighTIFFCompress=SLZW
LowJPEGQuality=70
LowJPEGSmooth=70
LowPNGInterlace=FALSE
LowTIFFCompress=SLZW
[KeyFile]
IconSize=16
KEYFILENAME=EDIT
KEYFILENAME2=MODEL
KEYFILENAME3=Architect
KEYFILENAME4=Notate
Standard=
Use External Icons=FALSE
[KnockOuts]
Draw First In Symbols=FALSE
[LineTypes]
Converted=TRUE
ShowExternal=TRUE
[Mask]
UseGlobalMask=TRUE
[MenuBtn]
BTN_HEIGHT=0
BTN_SPACING=1
BTN_WIDTH=12
Classic=FALSE
FONTNAME=MS Sans Serif
POINT_SIZE=10
ShortLabels=TRUE
STYLE=
SuppressLabels=FALSE
[MenuTextColor]
ActiveLyrBottomColor=
ActiveLyrDownColor=
ActiveLyrTopColor=
ActiveLyrUpColor=
BottomColor=
DownColor=
FunctionKey=148 148 128
HighLight=43 72 160
HighLightActiveLyrClr=43 72 160
HighLightActiveLyrTextClr=255 255 255
HighLightOffClr=43 72 160
HighLightOffTextClr=255 255 255
HighLightOnClr=43 72 160
HighLightOnTextClr=255 255 255
HighLightTextClr=255 255 255
LayerButtonActive=43 72 160
NormalButton=0 0 0
SlowFade=FALSE
ToggleButtonOff=153 0 51
ToggleButtonOn=90 117 42
ToggleOffBottomColor=
ToggleOffDownColor=
ToggleOffTopColor=
ToggleOffUpColor=
ToggleOnBottomColor=
ToggleOnDownColor=
ToggleOnTopColor=
ToggleOnUpColor=
TopColor=
UpColor=
[MSP]
ClipCube Extents=TRUE
[MultiView Windows]
Scale Correction Percentage=100
[No Preview File Dialog]
Last View=
[o2cViewer]
BackGround Bitmap=
BackGround Color=204 204 255
DragDrop=FALSE
ExtractedTexturePath=Textures\
ExtractTextures=TRUE
Filter=TRUE
FrontOverBack=TRUE
GroundPlane=FALSE
GroundPlaneAtBase=TRUE
GroundPlaneAtHeight=0
GroundPlaneEnlargeFactor=1.5
GroundPlaneMaterialFile=Materials\default.ini
Last=2
Lights=31
LoadDataCADView=FALSE
Material by Entity=TRUE
Material XOR Background=TRUE
MatNone Has Texture=FALSE
MatNone Highlight Size=2
MatNone Opacity=100
MatNone Reflection Ambient=50
MatNone Reflection Diffuse=40
MatNone Reflection Specular=10
MatNone Refraction=10
MatNone Render Backface=TRUE
MatNone Self-Illuminate=FALSE
MatNone Smooth Edges=TRUE
MatNone Texture Colorize=FALSE
MatNone Texture Mask=FALSE
MatNone Texture Reflection=FALSE
MatNone Texture Scale=1
MaxPolygonsPerMaterial=16380
MergeTextures=FALSE
Model_Z_Angle=0
Objects By=Layer
OverwriteTextures=FALSE
Remember Last View=FALSE
Scroll Bars=FALSE
Smooth Angle=30
Smooth Distance=0
Texture 3ds=2
Texture_Z_Angle=0
ThreeSidedOnly=FALSE
UseXREFLights=FALSE
[Object Snap Toolbar]
All Off=TRUE
Aperture On/Off=TRUE
Center Point=TRUE
End Point=TRUE
Fast 3D=TRUE
Fast Symbol=TRUE
Intersection=TRUE
Layer Snap=TRUE
Mid Point=TRUE
Miss Distance=TRUE
Nearest=FALSE
Number of Points=TRUE
Offset Distance=TRUE
Offset=TRUE
On Screen=TRUE
Perpendicular=TRUE
Quadrant=TRUE
Quick=TRUE
Search Hatch=TRUE
Selection Set=TRUE
Tangent=TRUE
Virtual=TRUE
[PakNGo]
Backup Bitmaps=FALSE
Backup Fonts=FALSE
Backup Materials=FALSE
Backup Pen Tables=FALSE
Backup XREFs=FALSE
Recreate Folder Structure=FALSE
[PaletteFile]
ColorA=FFFFFFFF
ColorB=FFFFFFFF
ColorC=FFFFFFFF
ColorD=FFFFFFFF
ColorE=FFFFFFFF
ColorF=FFFFFFFF
ColorG=FFFFFFFF
ColorH=FFFFFFFF
ColorI=FFFFFFFF
ColorJ=FFFFFFFF
ColorK=FFFFFFFF
ColorL=FFFFFFFF
ColorM=FFFFFFFF
ColorN=FFFFFFFF
ColorO=FFFFFFFF
ColorP=FFFFFFFF
Display RGB Push Percentage=33
Display RGB Push Threshold=64
Display RGB Push=FALSE
DoCustomColors=FALSE
MaxColorsInKey=15
PenFile=
Plotter RGB Push Percentage=33
Plotter RGB Push Threshold=64
Plotter RGB Push=FALSE
RGBFile=DATACAD COLOR.RGB
Store In Drawing=TRUE
[Paragraph Text]
Line Feed Distance Equals Text Height=FALSE
[Plot Preview]
DoPreview=TRUE
MaxBitmapMegaBytes=2
MultiMetafile=TRUE
No Spacebar=FALSE
PDFLayering=0
[Printer]
Clear Settings=FALSE
FitTo Adjustment=0
Multi-Layout Percentage=100
New FitTo=TRUE
New Initialize=TRUE
Optimized Draw=TRUE
Print Associative Dimensions=DEFAULT
Print Bitmaps=DEFAULT
Print Fills=DEFAULT
Print Hatch=DEFAULT
Print Knockouts=DEFAULT
Print Line Types=DEFAULT
Print Line Weight=DEFAULT
Print Smart Wall Fill=DEFAULT
Print Smart Wall Hatch=DEFAULT
Print Text=DEFAULT
Settings Auto Load=FALSE
Strong Printer Checks=TRUE
[Purge]
HatchPatterns(Automatic)=TRUE
HatchPatterns(Manual)=FALSE
Layers(Automatic)=FALSE
Layers(Manual)=FALSE
LineTypes(Automatic)=TRUE
LineTypes(Manual)=FALSE
Materials(Automatic)=FALSE
Materials(Manual)=FALSE
Styles(Automatic)=FALSE
Styles(Manual)=FALSE
Symbols(Automatic)=TRUE
Symbols(Manual)=FALSE
[Recent File List]
FILE1=P:\Union Bank - Morrisville\Drawings\EHD CAD Files\Development\A401-Interior Elevations.aec
FILE10=P:\VTrans Projects\2017-WRJ Dist 4 Office Building\Drawings\Development\A101-Floor Plans.aec
FILE2=P:\Union Bank - Morrisville\Drawings\EHD CAD Files\Development\A101-Floor Plans.aec
FILE3=P:\Union Bank - Morrisville\Drawings\EHD CAD Files\Development\A501-Details.aec
FILE4=P:\Union Bank - Morrisville\Drawings\EHD CAD Files\Development\A000-General Conditions.aec
FILE5=P:\Union Bank - Morrisville\Drawings\EHD CAD Files\Development\A201-Building Elevations.aec
FILE6=R:\2014 Archived Projects\Lyndon Savings Bank Projects\Lyndon S.B. - St. J\Drawings\ConDocs\A3-Elevations.aec
FILE7=P:\Union Bank - Morrisville\Drawings\EHD CAD Files\Development\A102-Ceiling-Roof Plans.aec
FILE8=P:\VTrans Projects\2017-WRJ Dist 4 Office Building\Drawings\Development\A501-Sections and Details.aec
FILE9=P:\VTrans Projects\2017-WRJ Dist 4 Office Building\Drawings\Development\A502-Details.aec
Max=10
[Recent Folder List]
DIR1=P:\Union Bank - Morrisville\Drawings\EHD CAD Files\Development\
DIR10=S:\EHD Office Info\Computer Info\Network Documentation\
DIR2=R:\2014 Archived Projects\Lyndon Savings Bank Projects\Lyndon S.B. - St. J\Drawings\ConDocs\
DIR3=P:\VTrans Projects\2017-WRJ Dist 4 Office Building\Drawings\Development\
DIR4=P:\Union Bank - Morrisville\Drawings\EHD CAD Files\Development\Details\
DIR5=P:\VELCO - Engineering Renovation\Drawings\ConDocs\
DIR6=C:\Users\CAD1\Desktop\
DIR7=P:\Twin State Ford\Drawings\ConDocs\
DIR8=P:\Bethlehem Public Library\Drawings\ConDocs\
DIR9=P:\VELCO - New Warehouse\Drawings\ConDocs\
Max=10
[Rendering Toolbar]
Edit Materials=TRUE
Layout Testing=FALSE
Load Materials=TRUE
Material By Color=TRUE
Material By Layer=TRUE
Object Viewer=TRUE
Rendering Preferences=TRUE
Rendering Settings=TRUE
Sun Shader=TRUE
[Screen Calibration]
Calibrated=FALSE
CalLineHeight=0
CalLineHeightPixels=0
CalLineWidth=0
CalLineWidthPixels=0
Units=0
[Single Line Text]
Line Feed Distance Equals Text Height=TRUE
[SketchUp]
City=Avon (CT)
Country=USA
DaylightSavings=FALSE
DisplayShadows=TRUE
EdgesCastShadows=FALSE
Export XRefs as Symbols=FALSE
ExtractTextures=FALSE
FrontOverBack=FALSE
Hide Edges=FALSE
Last Export=1
Latitude=41.8065
LaunchOnExport=FALSE
Longitude=-72.8418
Old Translator=FALSE
ShadowTimeDate=21
ShadowTimeHour=12
ShadowTimeMin=0
ShadowTimeMonth=6
TZOffset=-5
[Smart Walls]
Auto Cap Stepped Walls=TRUE
[SSCE User]
AllowAccentedCaps=1
AutoCorrect=0
CaseSensitive=1
DialogOriginX=899
DialogOriginY=646
HelpFile=C:\DataCAD 19\Help\SSCE.HLP
IgnoreAllCapsWords=0
IgnoreCappedWords=0
IgnoreDomainNames=0
IgnoreHTMLMarkups=0
IgnoreMixedCase=0
IgnoreMixedDigits=0
IgnoreNonAlphaWords=1
LastSelectedLex=userdic.tlx
MainLexFiles=ssceam.tlx,ssceam2.clx
MainLexPath=C:\DataCAD 19\Support Files\Dictionaries
MinSuggestDepth=50
PhoneticSuggestions=0
ReportDoubledWords=0
SplitContractedWords=0
SplitHyphenatedWords=1
SplitWords=0
StripPossessives=1
SuggestSplitWords=0
TypographicalSuggestions=1
UserLexFiles=userdic.tlx,correct.tlx
UserLexPath=C:\DataCAD 19\Support Files\Dictionaries
[Stamp]
AllowFileModified=TRUE
CaseSensitive=TRUE
ClipboardExpand=FALSE
ComputerName=@COMPUTERNAME
CustomDate=@PLTDATECUSTOM
CustomDateFormat=ddddd
CustomDateMenuText=
CustomTime=@PLTTIMECUSTOM
CustomTimeFormat=t
CustomTimeMenuText=
DoStamp=TRUE
DWGExpand=FALSE
DwgFullName=@DWGFULLNAME
DwgFullNameExt=@DWGFULLNAMEEXT
DwgModifiedDate=@DWGMODIFIEDDATE
DwgModifiedDateTime=@DWGMODIFIEDDATETIME
DwgModifiedTime=@DWGMODIFIEDTIME
DwgName=@DWGNAME
DwgNameExt=@DWGNAMEEXT
DwgPath=@DWGPATH
MaxMenuChars=60
PlotDate=@PLTDATE
PlotDateLong=@PLTDATELONG
PlotDay=@PLTDAY
PlotDayLong=@PLTDAYLONG
PLOTSCALE_1=@PLOTSCALE
PLOTSCALE_1MenuText=Plot Scale
PlotScale=@PLOTSCALE
PlotScaleMenuText=
PlotTime=@PLTTIME
PlotTime24=@PLTTIME24
Substitute=@PLTSUBSTITUTE
SubstituteMenuText=
SubstituteTo=@USERNAME plotted this drawing (@DWGNAME) on @PLTDAYLONG.
User_1=@Office
User_1MenuText=Office
UserChangeTo_1=Irvine
UserName=@USERNAME
[Standard Toolbar]
STD_ClipboardSelect=TRUE
STD_Copy=TRUE
STD_Cut=TRUE
STD_Help=TRUE
STD_Hyperlink=TRUE
STD_InsertBMP=TRUE
STD_InsertXREF=TRUE
STD_NewFile=TRUE
STD_OpenFile=TRUE
STD_Order=TRUE
STD_Paste=TRUE
STD_Print=TRUE
STD_Redo=TRUE
STD_Save=TRUE
STD_SpellCheck=TRUE
STD_Undo=TRUE
[StatusArea]
ButtonColors=TRUE
ButtonDoorTypes=TRUE
ButtonGotoViews=TRUE
ButtonLayers=TRUE
ButtonLayerSearch=TRUE
ButtonLineTypes=TRUE
ButtonPlotterMenu=FALSE
ButtonScales=TRUE
ButtonSelSets=TRUE
ButtonWallTypes=TRUE
ButtonWindowTypes=TRUE
DropDownColors=TRUE
DropDownDoorTypes=TRUE
DropDownGotoViews=TRUE
DropDownInputModes=TRUE
DropDownLayers=TRUE
DropDownLineTypes=TRUE
DropDownPlotScales=FALSE
DropDownScales=TRUE
DropDownSelSets=TRUE
DropDownWallTypes=TRUE
DropDownWidth=45
DropDownWindowTypes=TRUE
MaxColors=15
MaxDoorTypes=15
MaxGotoViews=15
MaxLayers=15
MaxLineTypes=15
MaxScales=15
MaxWallTypes=15
MaxWindowTypes=15
[Sun Shader]
Apply Filters To Embedded Entities=TRUE
Force Ground Plane display for Shadow Study=TRUE
Force Solid Background=FALSE
[Symbol Attributes]
Databases Have Header Row=FALSE
New Database Linking=TRUE
ShowAllFieldsInLookUp=FALSE
[SymbolBrowser]
AutoDivisions=FALSE
BrowseType=FOLDER
ConvDSFToO2C=FALSE
ConvSM3ToDSF=FALSE
ConvSM3ToO2C=FALSE
DIR1=T:\Details\Studs\
DIR10=T:\Drawing\North Arrows\
DIR2=T:\Borders\EHD-11x17\
DIR3=T:\Electrical\Reflected Ceiling\
DIR4=T:\Borders\Covers\
DIR5=T:\Moulding-Brosco\Casing\
DIR6=T:\Moulding-Brosco\Base\
DIR7=T:\Drawing\Detail Grid 24x36\
DIR8=T:\Electrical\Receptacle\
DIR9=T:\Office\2D Plans\
DockWidth=0
FAVORITE1=T:\Drawing\Detail Grid 24x36\
FAVORITE2=T:\Drawing\Detail-Grid 30x42\
FAVORITE3=T:\Drawing\Symbols-Small\
FAVORITE4=T:\Borders\EHD-24x36\
FAVORITE5=T:\Drawing\Symbols\
Inherit Parent Input Mode=TRUE
Loaded Indicators=FALSE
Max Favorites=10
Max Recent=10
MaxAutoDivisionsX=3
MaxAutoDivisionsY=15
Resizable Folder Browser=TRUE
Sort Favorites=FALSE
Sort Recent=FALSE
Symbol Scale by Folder=FALSE
SymbolFolder=T:\Drawing\Symbols-Small\
TemplateFile=C:\DataCAD 19\Templates\
Windows Cursor=FALSE
[TemplateWindow]
IsometricOn=FALSE
Symbol Scale by Template=FALSE
Width=
[Text Editor]
Current Zoom=100
[Toolbars]
DockedCloseButton=TRUE
FontName=MS Sans Serif
HideWhenInactive=TRUE
Locked=1
Point_Size=10
Resizable=FALSE
Stretched=TRUE
Style=
Suppress Macro Hint Toolbar=FALSE
[Undo]
Disable During Import=TRUE
Disabled=FALSE
Suspend During Section=TRUE
TreatMacroAsTransaction=FALSE
[Update]
Initial 14=4/14/2017
[Viewer Toolbar]
Add GoTo View=TRUE
Clip Cube On=TRUE
Hidden Line Removal=TRUE
Look Down=TRUE
Look Left=TRUE
Look Right=TRUE
Look Up=TRUE
New Clip Cube=TRUE
Object Viewer=TRUE
OpenGL Shader=TRUE
Refresh View=TRUE
Rotate +X=TRUE
Rotate +Y=TRUE
Rotate -X=TRUE
Rotate -Y=TRUE
Step Down=TRUE
Step Left=TRUE
Step Right=TRUE
Step Up=TRUE
Sun Shader=TRUE
Update GoTo View=TRUE
Walk Backward=TRUE
Walk Forward=TRUE
[XREFs]
Allow Nesting=TRUE
Always Update GTV Links=FALSE
Auto Convert=FALSE
Dynamic Snapping=TRUE
New Check For Nested=TRUE
Warn On Nested Orphans=TRUE
XRefs Auto-Refresh on Regen=TRUE
[ToolBox]
MCR_01=C:\DataCAD 19\Macros\3DLINCVT.DCX
MCR_02=C:\DataCAD 19\Macros\3DSTAIRS.DCX
MCR_03=C:\DataCAD 19\Macros\AEC_MODL.DCX
MCR_04=C:\DataCAD 19\Macros\CONCRETE.DCX
MCR_05=C:\DataCAD 19\Macros\DCAD_AEC.DCX
MCR_06=C:\DataCAD 19\Macros\EZTOOLS.DCX
MCR_07=C:\DataCAD 19\Macros\FORMATR.DCX
MCR_08=C:\DataCAD 19\Macros\FRAMEIT.DCX
MCR_09=C:\DataCAD 19\Macros\LIN2WALL.DCX
MCR_10=C:\DataCAD 19\Macros\RAMPMSTR.DCX
MCR_11=C:\DataCAD 19\Macros\ROOFIT.DCX
MCR_12=C:\DataCAD 19\Macros\STEELPRO.DCX
[Layer Manager]
IndexColWidth=28
OnOffColWidth=26
LockedColWidth=32
ColorColWidth=32
NameColWidth=158
CountColWidth=50
ReadBitmaps=FALSE
Persistent=FALSE
List Font Name=MS Sans Serif
List Font Size=10
#72353 by Mark Bell
Wed Sep 20, 2017 5:38 pm
Arthur wrote "I don't know if there is something in the file coding that is telling the file to look in the folder Datacad 18/Support Files/Pen Tables (which doesn't existing any more) for the pen table versus the new "Default" folder location Datacad 19/Support Files/Pen Tables."
Just a suggestion - have you considered rebuilding the former path? I had an instance earlier in the year with another program where I removed the old version then found not everything worked in the new version. Something hadn't been completed with the new installation/copy over of previous data that was preventing it working properly. I've also had issues with Sunshader not working on an older Win7 PC and judging by the feedback on the Forum I was probably the only one experiencing the problem, as you are with the pen table issue. To me, this suggests the problem isn't wholly with DataCAD but perhaps Windows not completing a task fully and in your case, may be not have completed the transfer to the v19 folders?
Another suggestion - try using a different plotter driver to see if it affects the print output.
#72354 by joshhuggins
Wed Sep 20, 2017 6:04 pm
Sorry not seeing anything here out of place. :? Dave mentioned absolute paths vs relative. Maybe try changing the following line to an absolute path
Code: Select all[Paths]
PATH_PENTABLE=C:\Datacad 19\SUPPORT FILES\PEN TABLES\
If that doesn't work I would try working with a fresh install of v19. I would probably do the following as a test.
-Backup my current working Datacad folder somewhere.
- Uninstall any versions of Datacad
- Delete any Datacad program folders that might be left over
- Reboot
-Run something like CCLeaner to clean the registry
- Reboot
- Install Datacad 19. (I might try at this point installing it to a new path like C:\Datacad 19x
- Copy your pen table over to the new Pen Table folder using the relative path first, then run a print.
- If that didn't work then I would try it with the absolute path and then try to print again.
- If that didn't work then I'd go have a drink somewhere :D
Good luck, I feel your pain!
#72357 by artmanvt2000
Thu Sep 21, 2017 6:35 am
Josh,
I will try the direct path approach. Doing the other will take some time. I have four computers here at the office that I will need to do that to. If the path change works I won't do the other.
#72359 by artmanvt2000
Thu Sep 21, 2017 6:56 am
Josh,
I just tried the recommendation of the path name change. It did not work. I guess I will try the re-install when I get some time.
