#72968 by Rod Jeheber
Wed Dec 27, 2017 3:30 pm
Maybe I am losing my mind, but if I drew a square using four lines (not the rectangle button) the four lines would ALL be grouped together right?
For some odd reason now, this is not happening. If I click "move" and select "group" only three of the four lines will be highlighted.
Any one else experiencing this issue?
#73016 by Roger D
Fri Jan 05, 2018 2:46 pm
I just tried that in v19, can not duplicate. all 4 walls are part of same group.
#73073 by Rod Jeheber
Fri Jan 12, 2018 7:17 pm
Thanks for the phone call David!
Turns out I found a bug in the helplines menu - Well, technically David G. figured it out.
Turn off "Show" under the "Helplines" and this problem goes away until the next update!
Cheers,
Rod
Users browsing this forum: No registered users and 75 guests
