#73025 by jimgoodman
Sun Jan 07, 2018 12:48 pm
I am updating our default drawings. Is there a way to select all layers in a drawing and set global z-base & z-height values? These are empty layers without any entities.
Ideally, all layers could be selected in the layer manager with "Z by layer" checked and enter the new global z base and z height.
Thanks
#73029 by ORWoody
Sun Jan 07, 2018 8:13 pm
Are the Z-Base and Z-Height layer independent?
If you have your Z settings at 0, I think all are at 0.
If you have entities on multiple layers that you also want to be at 0, just turn all layers On and Window extents. Change by area to 0 and 0 and you would be finished.
I hope this is what you were asking. Since it was really about empty default drawings the Z settings should be global.
If it isn't a global setting, I've sure been using it incorrectly for a long time.
Woody
#73083 by dhs
Mon Jan 15, 2018 3:43 pm
It would be easy to write a macro to do what you are requesting. Try the one I have uploaded to !
This is a very basic macro that took less than half an hour to write and I have only done very basic testing, so use it at your own risk! But I think it does what you want.
I have included the source code in the z file in case anybody feels the need to enhance it. I may add a bit more functionality myself and release it on my web site when I get time (yes Jim, I am still working on the thing you requested a few months ago ... but not spending much time on DataCAD just at the moment).
#73085 by jimgoodman
Tue Jan 16, 2018 8:30 am
Thanks David:
I am traveling today but will give this a try this evening or tomorrow morning.
I need to do some additional testing on the other macro as well.
#73103 by jimgoodman
Wed Jan 17, 2018 5:55 pm
I see how it works now.
I had "Z by Layer" checked and when I unchecked it, all the layers were changed to the values set in the macro. If I check "Z by Layer" again, each layer now has the global value.
Very cool
