Why does this happen sometimes? Can't identify or do anything with it. Can't remember how to rectify this.
Maybe check that your S4 Object Snap, S4 Miss Distance is set to about 10?
Thanks for the reply, Josh. This has happened to me, occasionally, over the years. I was finally able to erase the entity and hit redo. That brought things back to normal.
Don't know why that worked, but it did, so I'm happy. I recently upgraded to V19, and the other day, I ran into another old intermittent problem.When doing a stringline of dimensions, one of them comes up with an extra
1/32", but when I finish it and do overall, the total is correct. I was hoping that problem was corrected by now.
Thanks for the help.
Bob
Bob
Bob Urbanek wrote:Thanks for the reply, Josh. This has happened to me, occasionally, over the years. I was finally able to erase the entity and hit redo. That brought things back to normal.The problem is most likely with the entities being dimensioned. Try going to the Utility Menu, F0 Settings, S2 Scale Type, and set the precision to 256. Also check to see if Rounding is turned on in the Dimension menu. Check your dimensions again and / or Identify your entities to see if you have entities or spaces that are actually fractions of an inch off. Correct dimensions as needed and then you can reset your scale precision to something more reasonable if you wish like 32nds' or 64ths'.
Bob
Thanks again Josh. I've been busy, and haven't got back to dealing with this. At the moment, I have a cold or the flu, and because I am bored, I reread your reply. Rounding was off in the dimensions setting. Turned it on, and it seems to have fixed the problem. ( I hope ) This has been an irritation for me for years. Not a big deal, but it is a deal. You guys are all great! I know it is a minor thing, but nevertheless enough to make me utter bad words. I have noticed that you have helped many people over the years, and I commend you for it.
Thanks, Bob
Thanks, Bob
Users browsing this forum: No registered users and 44 guests
