#73240 by Tim Mohr
Sat Feb 10, 2018 3:49 pm
Is there a macro out there from times gone by that will do a batch conversion of line entities to polylines? specifically I am looking for a way to hatch shapes drawn with lines ... my current (and long term) solution is to export to autocad, hatch the shapes in question and then export/import it back into datacad...
#73243 by Tim Mohr
Sun Feb 11, 2018 12:43 pm
I usually avoid this as an issue by simply drawing with polylines if I know I am likely to want to hatch the result or use it as an overlay/knockout. However, sometimes it's easier to use the multi-line function with its ability to set offsets, auto-clean intersections, etc.when drawing some sort of matrix but hatching this is a different story as it's tedious to pick each space and/or to run through the "line to polyline" function - the easy fix is to simply export to dwg and bring it back in which will converted all of the (presumably closed) shapes to polylines...
#73246 by Roger D
Sun Feb 11, 2018 7:22 pm
Another option. Copy the smart walls to a new layer. You might also have to move z by say 10' so the openings do not cut the walls. Then Tools/Extract 2d/3d /Extract 2d this will change the smart wals in to 2d lines on a layer call walls_2d. Then you can hatch using that layer and Controur Search.
#73247 by Tim Mohr
Sun Feb 11, 2018 7:45 pm
Thanks for all of the suggestions everyone...basically I am just dealing with a flat matrix aka winodow mull options and I did it with the multi-lines - just looking for a way to hatch without having to retrace my steps...if I export to dwg and then Hatch it in ACAD, I can then reopen in DCAD and the matrix will have been effectively converted to a polyline...point is ACAD can recognize closed shapes drawn with lines ....ie do this in one step. Just was hoping someone had written a macro that would do this...will check out the sundry suggestions but all seem like work arounds-for which I have a reasonably easy solution already...? Thanks. Tim
Users browsing this forum: No registered users and 48 guests
