I'll start this off with a request from Tina here in the office: can we remove a Symbol Browser favorite folder from the program preferences, or the SB menu, please? We can edit the Dcadwin.ini file, but this is more involved than many folks want to get into.
I second that emotion....
James Goodman, AIA
Capistrano Beach, CA
Since V2.5f (1985)
Since V2.5f (1985)
A recurring wish: text search, and search and replace - PLEASE?
Does Scrive work with ParaText and MText?
No. I think we had this discussion a while ago.
I don't think MText or PText are accessible from DCAL at all. My wish would be that they could be added to the DCAL capabilities (along with smart walls and others that have also not been added to DCAL)....
David Henderson
Right - I hope we get Search and Search & Replace functions built into DataCAD.
I would love it if 3D Clip Cubes "overruled" X-Clip's and S-Clip's. Having stuff show outside a 3D Clip Cube means you have to go through creating new layers, and update GTV's etc.
Here's a behavior that doesn't usually matter, but in this case, it does: I am using the linetype called "Corugate" (that is the spelling). And when I use a Clip Cube to make a detail - the spacing of the Corugate line changes. I am guessing the spacing is based on the portion of the line in the CC is different than without it.
Is it possible prevent the linetype spacing from changing with a CC?
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
I'm not seeing a change in Spacing when a Clip Cube is involved. In the attached image, there are 3 Lines drawn with that linetype with 2 of them being clipped by the Clip Cube. To the right is a Symbol comprised of Lines with the same linetype and set to Ignore Clip Cubes. I can see no difference in their spacing.
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
Okay, I am not using a symbol. Here's what I have - a building section, and the Corugate line is the steel pan in the floor slab. I have turned off the display of hatch, so you can see the polyline outline, as the reference. Here's a part of one of the cross sections, without the CC:
And here's the exact same part, but with a CC:
Turn off End Correction for that line type in the [b]Line Type Manager[b/]?
David A. Giesselman
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
Users browsing this forum: No registered users and 113 guests
