#74328 by Neil Blanchard
Fri Jul 13, 2018 10:22 am
Hi Folks,
I just figured out how to workaround an issue, that you may have also run into - if you have a detail that uses a Clip Cube, you can use a symbol for the title bubble. By toggling on Ignore Clip Cubes, that symbol shows up outside the CC - but if the title needs to be longer than the line in the symbol, it looks wrong.
My workaround is to use a Smart Arrow with the arrow size set to zero, to extend the line - because Smart Arrows can also be set to Ignore Clip Cube. And a farther trick is to Copy the smart arrow (after you have toggled on the Ignore CC setting) to the clipboard - and paste it as needed. This lets you set the arrowhead size back to your standard.
