Using DC 15 and Win 10. When I create several Go to Views to use for mult-layout only the last created one shows in the window and none in dropdown. None are in the list of views in the muti-layout. Never had this before. Copied original file to new one but did not help. Even lost them in an older file I opened up. Help please.
Thanks! - Josh
I did not have this problem before with DC 15 which was running Win 10 which an update from a previous version. I just bought a new computer with Win 10 already installed. This is the 1st project I have started using it. I have gone back to a project done before the new computer and put a previously created view into Multi-Layout, name and save it then go out of Multi-Layout and back again. It is no longer there. The drop down shows all the GTV created. They do not appear in it after creating views.
Hi Richard,
Do you have the same printer/plotter driver installed on the new computer?
Newer versions of Windows change - the way that older versions of any program interact with the operating system cannot be known ahead of time. If all your older hardware (printers, scanners, etc.) continue to work, then consider yourself lucky. Same goes - but even more so - for older programs.
Be sure to try running as administrator.
Still cannot get this to work. I make views but when I go to Multi-layout/Go to View there are none there. Using DC 16. Has anyone else had this problem?
what version windows are you on?
Does this happen in only new files? old files?
Using Win7, DC Ver 16.03.00.12, opened a blank file, drew a few lines, made a view, went to plotter, selected a printer, multilayoout, GoTYoView and it showed up.
Win 10 on new computer. Checked earlier files done on previous computer, also Win 10, transferred over to the new computer and they also are now missing the Go To Views. New computer is HP Pavilion. Every thing else works fine except the Go To View.
I did the same thing as Roger, named the view, saved it, went back out, came back again to the sheet and it was gone???????
Users browsing this forum: No registered users and 58 guests
