Neil wrote: Here's a doable request: create a polyline rectangle with filleted corners? Set the fillet radius, and click-drag-click a rectangle. If the radius is too big for the short side, reduce it to 40% of the short side.
Josh wrote: I'd say that if the radius didn't fit then to just not do it
I've updated my dhBox macro to allow filleted corners as well as a polyline option. I think it all works ok, but is only a beta version at the moment.
I would be grateful to receive any feedback if anybody would care to have a look at it (you can download it at
http://www.dhsoftware.com.au/downloads/beta/DHBOX.zip).
I think the options are fairly self explanatory, but to comply with the Neil's and Josh's suggestions of what to do if the fillet size doesn't fit you would use F8 to enter a percentage (of 40% for Neil, 0% for Josh), then select F9 to enter an actual size (and leave F9 selected after entering the size).
The size specification also has an optional 'Text Scale' option (ok, it's not text, but I felt most people will know what I mean by that rather than calling it something else like 'Plot Scale' - any suggestions in the naming of that option would be welcome!)
David H.
