We need King Brick Herringbone for DataCAD17 do you know where I can save this to upload in the hatch manager? It would be ideal to be able to create our own hatches. Any help is much apprectiated!
What are the dimensions of this brick? Do you have the hatch pattern of a standard brick herringbone? If so, you may be able to save a copy, and edit the numbers to get the pattern you need, with some trial and error.
You might try this from Josh Huggins' web site.
http://joshhuggins.com/product/unilock-paver-hatch/
Here is a pattern that I wrote up today. Hopefully, it works for you.
It is a 3X10 layout. Use at a scale of 1 and at a 45 degree angle for the VVV typical for Herringbone.
Hmmm. I'm not seeing the file as an attachment. I get a message that the dhp extension is not allowed. Since it's not accessible, please contact me at orwoody@gmail.com and I'll send it to you directly.
Good luck and have a Merry Christmas.
Woody
Woody
Woody,
You can post the contents of the file directly, using the
Code: Select all
- and then we can Copy and Paste it to make our own DHP file.Code display
Code: Select all
;| Hatch Pattern (c) 2018 - Oran Woody |
;| King Herringbone 3x10 |
[Header]
Scale=1
Angle=0
Display Scale=1
Segments=320
[Segments]
001=0, 0, 0, 0, 0, 3840, 3840, 416, -1504
002=0, 0, 90, 96, 0, 3840, 3840, 416, -1504
003=0, 0, 0, 96, 96, 3840, 3840, 416, -1504
004=0, 0, 90, 192, 96, 3840, 3840, 416, -1504
005=0, 0, 0, 192, 192, 3840, 3840, 416, -1504
006=0, 0, 90, 288, 192, 3840, 3840, 416, -1504
007=0, 0, 0, 288, 288, 3840, 3840, 416, -1504
008=0, 0, 90, 384, 288,3 840, 3840, 416, -1504
009=0, 0, 0, 384, 384, 3840, 3840, 416, -1504
010=0,0, 90, 480, 384, 3840, 3840, 416, -1504
011=0, 0, 0, 480, 480, 3840, 3840, 416, -1504
012=0,0, 90, 576, 480, 3840, 3840, 416, -1504
013=0, 0, 0, 576, 576, 3840, 3840, 416, -1504
014=0,0, 90, 672, 576, 3840, 3840, 416, -1504
015=0, 0, 0, 672, 672, 3840, 3840, 416, -1504
016=0,0, 90, 768, 672, 3840, 3840, 416, -1504
017=0, 0, 0, 768, 768, 3840, 3840, 416, -1504
018=0,0, 90, 864, 768, 3840, 3840, 416, -1504
019=0, 0, 0, 864, 864, 3840, 3840, 416, -1504
020=0,0, 90, 960, 864, 3840, 3840, 416, -1504
021=0, 0, 0, 960, 960, 3840, 3840, 416, -1504
022=0,0, 90, 1056, 960, 3840, 3840, 416, -1504
023=0, 0, 0, 1056, 1056, 3840, 3840, 416, -1504
024=0,0, 90, 1152, 1056, 3840, 3840, 416, -1504
025=0, 0, 0, 1152, 1152, 3840, 3840, 416, -1504
026=0,0, 90, 1248, 1152, 3840, 3840, 416, -1504
027=0, 0, 0, 1248, 1248, 3840, 3840, 416, -1504
028=0,0, 90, 1344, 1248, 3840, 3840, 416, -1504
029=0, 0, 0, 1344, 1344, 3840, 3840, 416, -1504
030=0,0, 90, 1440, 1344, 3840, 3840, 416, -1504
031=0, 0, 0, 1440, 1440, 3840, 3840, 416, -1504
032=0,0, 90, 1536, 1440, 3840, 3840, 416, -1504
033=0, 0, 0, 1536, 1536, 3840, 3840, 416, -1504
034=0,0, 90, 1632, 1536, 3840, 3840, 416, -1504
035=0, 0, 0, 1632, 1632, 3840, 3840, 416, -1504
036=0,0, 90, 1728, 1632, 3840, 3840, 416, -1504
037=0, 0, 0, 1728, 1728, 3840, 3840, 416, -1504
038=0,0, 90, 1824, 1728, 3840, 3840, 416, -1504
039=0, 0, 0, 1824, 1824, 3840, 3840, 416, -1504
040=0,0, 90, 1920, 1824, 3840, 3840, 416, -1504
041=0, 0, 0, 1920, 1920, 3840, 3840, 416, -1504
042=0,0, 90, 2016, 1920, 3840, 3840, 416, -1504
043=0, 0, 0, 2016, 2016, 3840, 3840, 416, -1504
044=0,0, 90, 2112, 2016, 3840, 3840, 416, -1504
045=0, 0, 0, 2112, 2112, 3840, 3840, 416, -1504
046=0,0, 90, 2208, 2112, 3840, 3840, 416, -1504
047=0, 0, 0, 2208, 2208, 3840, 3840, 416, -1504
048=0,0, 90, 2304, 2208, 3840, 3840, 416, -1504
049=0, 0, 0, 2304, 2304, 3840, 3840, 416, -1504
050=0,0, 90, 2400, 2304, 3840, 3840, 416, -1504
051=0, 0, 0, 2400, 2400, 3840, 3840, 416, -1504
052=0,0, 90, 2496, 2400, 3840, 3840, 416, -1504
053=0, 0, 0, 2496, 2496, 3840, 3840, 416, -1504
054=0,0, 90, 2592, 2496, 3840, 3840, 416, -1504
055=0, 0, 0, 2592, 2592, 3840, 3840, 416, -1504
056=0,0, 90, 2688, 2592, 3840, 3840, 416, -1504
057=0, 0, 0, 2688, 2688, 3840, 3840, 416, -1504
058=0,0, 90, 2784, 2688, 3840, 3840, 416, -1504
059=0, 0, 0, 2784, 2784, 3840, 3840, 416, -1504
060=0,0, 90, 2880, 2784, 3840, 3840, 416, -1504
061=0, 0, 0, 2880, 2880, 3840, 3840, 416, -1504
062=0,0, 90, 2976, 2880, 3840, 3840, 416, -1504
063=0, 0, 0, 2976, 2976, 3840, 3840, 416, -1504
064=0,0, 90, 3072, 2976, 3840, 3840, 416, -1504
065=0, 0, 0, 3072, 3072, 3840, 3840, 416, -1504
066=0,0, 90, 3168, 3072, 3840, 3840, 416, -1504
067=0, 0, 0, 3168, 3168, 3840, 3840, 416, -1504
068=0,0, 90, 3264, 3168, 3840, 3840, 416, -1504
069=0, 0, 0, 3264, 3264, 3840, 3840, 416, -1504
070=0,0, 90, 3360, 3264, 3840, 3840, 416, -1504
071=0, 0, 0, 3360, 3360, 3840, 3840, 416, -1504
072=0,0, 90, 3456, 3360, 3840, 3840, 416, -1504
073=0, 0, 0, 3456, 3456, 3840, 3840, 416, -1504
074=0,0, 90, 3552, 3456, 3840, 3840, 416, -1504
075=0, 0, 0, 3552, 3552, 3840, 3840, 416, -1504
076=0,0, 90, 3648, 3552, 3840, 3840, 416, -1504
077=0, 0, 0, 3648, 3648, 3840, 3840, 416, -1504
078=0,0, 90, 3744, 3648, 3840, 3840, 416, -1504
079=0, 0, 0, 3744, 3744, 3840, 3840, 416, -1504
080=0,0, 90, 3840, 3744, 3840, 3840, 416, -1504
081=0, 0, 0, 320, -320, 3840, 3840, 416, -1504
082=0, 0, 90, 416, -320, 3840, 3840, 416, -1504
083=0, 0, 0, 416, -224, 3840, 3840, 416, -1504
084=0, 0, 90, 512, -224, 3840, 3840, 416, -1504
085=0, 0, 0, 512, -128, 3840, 3840, 416, -1504
086=0, 0, 90, 608, -128, 3840, 3840, 416, -1504
087=0, 0, 0, 608, -32, 3840, 3840, 416, -1504
088=0, 0, 90, 704, -32, 3840, 3840, 416, -1504
089=0, 0, 0, 704, 64, 3840, 3840, 416, -1504
090=0, 0, 90, 800, 64, 3840, 3840, 416, -1504
091=0, 0, 0, 800, 160, 3840, 3840, 416, -1504
092=0, 0, 90, 896, 160, 3840, 3840, 416, -1504
093=0, 0, 0, 896, 256, 3840, 3840, 416, -1504
094=0, 0, 90, 992, 256, 3840, 3840, 416, -1504
095=0, 0, 0, 992, 352, 3840, 3840, 416, -1504
096=0,0, 90, 1088, 352, 3840, 3840, 416, -1504
097=0, 0, 0, 1088, 448, 3840, 3840, 416, -1504
098=0,0, 90, 1184, 448, 3840, 3840, 416, -1504
099=0, 0, 0, 1184, 542, 3840, 3840, 416, -1504
100=0,0, 90, 1280, 542, 3840, 3840, 416, -1504
101=0, 0, 0, 1280, 638, 3840, 3840, 416, -1504
102=0,0, 90, 1376, 638, 3840, 3840, 416, -1504
103=0, 0, 0, 1376, 734, 3840, 3840, 416, -1504
104=0,0, 90, 1472, 734, 3840, 3840, 416, -1504
105=0, 0, 0, 1472, 830, 3840, 3840, 416, -1504
106=0,0, 90, 1568, 830, 3840, 3840, 416, -1504
107=0, 0, 0, 1568, 926, 3840, 3840, 416, -1504
108=0,0, 90, 1664, 926, 3840, 3840, 416, -1504
109=0, 0, 0, 1664, 1022, 3840, 3840, 416, -1504
110=0,0, 90, 1760, 1022, 3840, 3840, 416, -1504
111=0, 0, 0, 1760, 1118, 3840, 3840, 416, -1504
112=0,0, 90, 1856, 1118, 3840, 3840, 416, -1504
113=0, 0, 0, 1856, 1214, 3840, 3840, 416, -1504
114=0,0, 90, 1952, 1214, 3840, 3840, 416, -1504
115=0, 0, 0, 1952, 1310, 3840, 3840, 416, -1504
116=0,0, 90, 2048, 1310, 3840, 3840, 416, -1504
117=0, 0, 0, 2048, 1406, 3840, 3840, 416, -1504
118=0,0, 90, 2144, 1406, 3840, 3840, 416, -1504
119=0, 0, 0, 2144, 1502, 3840, 3840, 416, -1504
120=0,0, 90, 2240, 1502, 3840, 3840, 416, -1504
121=0, 0, 0, 2240, 1598, 3840, 3840, 416, -1504
122=0,0, 90, 2336, 1598, 3840, 3840, 416, -1504
123=0, 0, 0, 2336, 1694, 3840, 3840, 416, -1504
124=0,0, 90, 2432, 1694, 3840, 3840, 416, -1504
125=0, 0, 0, 2432, 1790, 3840, 3840, 416, -1504
126=0,0, 90, 2528, 1790, 3840, 3840, 416, -1504
127=0, 0, 0, 2528, 1886, 3840, 3840, 416, -1504
128=0,0, 90, 2624, 1886, 3840, 3840, 416, -1504
129=0, 0, 0, 2624, 1982, 3840, 3840, 416, -1504
130=0,0, 90, 2720, 1982, 3840, 3840, 416, -1504
131=0, 0, 0, 2720, 2078, 3840, 3840, 416, -1504
132=0,0, 90, 2816, 2078, 3840, 3840, 416, -1504
133=0, 0, 0, 2816, 2174, 3840, 3840, 416, -1504
134=0,0, 90, 2912, 2174, 3840, 3840, 416, -1504
135=0, 0, 0, 2912, 2270, 3840, 3840, 416, -1504
136=0,0, 90, 3008, 2270, 3840, 3840, 416, -1504
137=0, 0, 0, 3008, 2366, 3840, 3840, 416, -1504
138=0,0, 90, 3104, 2366, 3840, 3840, 416, -1504
139=0, 0, 0, 3104, 2462, 3840, 3840, 416, -1504
140=0,0, 90, 3200, 2462, 3840, 3840, 416, -1504
141=0, 0, 0, 3200, 2558, 3840, 3840, 416, -1504
142=0,0, 90, 3296, 2558, 3840, 3840, 416, -1504
143=0, 0, 0, 3296, 2654, 3840, 3840, 416, -1504
144=0,0, 90, 3392, 2654, 3840, 3840, 416, -1504
145=0, 0, 0, 3392, 2750, 3840, 3840, 416, -1504
146=0,0, 90, 3488, 2750, 3840, 3840, 416, -1504
147=0, 0, 0, 3488, 2846, 3840, 3840, 416, -1504
148=0,0, 90, 3584, 2846, 3840, 3840, 416, -1504
149=0, 0, 0, 3584, 2942, 3840, 3840, 416, -1504
150=0,0, 90, 3680, 2942, 3840, 3840, 416, -1504
151=0, 0, 0, 3680, 3038, 3840, 3840, 416, -1504
152=0,0, 90, 3776, 3038, 3840, 3840, 416, -1504
153=0, 0, 0, 3776, 3134, 3840, 3840, 416, -1504
154=0,0, 90, 3872, 3134, 3840, 3840, 416, -1504
155=0, 0, 0, 3872, 3230, 3840, 3840, 416, -1504
156=0,0, 90, 3968, 3230, 3840, 3840, 416, -1504
157=0, 0, 0, 3968, 3326, 3840, 3840, 416, -1504
158=0,0, 90, 4064, 3326, 3840, 3840, 416, -1504
159=0, 0, 0, 4064, 3422, 3840, 3840, 416, -1504
160=0,0, 90, 4160, 3422, 3840, 3840, 416, -1504
161=0, 0, 0, 640, -640, 3840, 3840, 416, -1504
162=0, 0, 90, 736, -640, 3840, 3840, 416, -1504
163=0, 0, 0, 736, -544, 3840, 3840, 416, -1504
164=0, 0, 90, 832, -544, 3840, 3840, 416, -1504
165=0, 0, 0, 832, -448, 3840, 3840, 416, -1504
166=0, 0, 90, 928, -448, 3840, 3840, 416, -1504
167=0, 0, 0, 928, -352, 3840, 3840, 416, -1504
168=0, 0, 90, 1024,-352, 3840, 3840, 416, -1504
169=0, 0, 0, 1024,-256, 3840, 3840, 416, -1504
170=0, 0, 90, 1120,-256, 3840, 3840, 416, -1504
171=0, 0, 0, 1120,-160, 3840, 3840, 416, -1504
172=0, 0, 90, 1216,-160, 3840, 3840, 416, -1504
173=0, 0, 0, 1216, -64, 3840, 3840, 416, -1504
174=0, 0, 90, 1312, -64, 3840, 3840, 416, -1504
175=0, 0, 0, 1312, 32, 3840, 3840, 416, -1504
176=0, 0, 90, 1408, 32, 3840, 3840, 416, -1504
177=0, 0, 0, 1408, 128, 3840, 3840, 416, -1504
178=0, 0, 90, 1504, 128, 3840, 3840, 416, -1504
179=0, 0, 0, 1504, 224, 3840, 3840, 416, -1504
180=0, 0, 90, 1600, 224, 3840, 3840, 416, -1504
181=0, 0, 0, 1600, 320, 3840, 3840, 416, -1504
182=0, 0, 90, 1696, 320, 3840, 3840, 416, -1504
183=0, 0, 0, 1696, 416, 3840, 3840, 416, -1504
184=0, 0, 90, 1792, 416, 3840, 3840, 416, -1504
185=0, 0, 0, 1792, 512, 3840, 3840, 416, -1504
186=0, 0, 90, 1888, 512, 3840, 3840, 416, -1504
187=0, 0, 0, 1888, 608, 3840, 3840, 416, -1504
188=0, 0, 90, 1984, 608, 3840, 3840, 416, -1504
189=0, 0, 0, 1984, 704, 3840, 3840, 416, -1504
190=0, 0, 90, 2080, 704, 3840, 3840, 416, -1504
191=0, 0, 0, 2080, 800, 3840, 3840, 416, -1504
192=0, 0, 90, 2176, 800, 3840, 3840, 416, -1504
193=0, 0, 0, 2176, 896, 3840, 3840, 416, -1504
194=0, 0, 90, 2272, 896, 3840, 3840, 416, -1504
195=0, 0, 0, 2272, 992, 3840, 3840, 416, -1504
196=0, 0, 90, 2368, 992, 3840, 3840, 416, -1504
197=0, 0, 0, 2368, 1088, 3840, 3840, 416, -1504
198=0, 0, 90, 2464, 1088, 3840, 3840, 416, -1504
199=0, 0, 0, 2464, 1184, 3840, 3840, 416, -1504
200=0, 0, 90, 2560, 1184, 3840, 3840, 416, -1504
201=0, 0, 0, 2560, 1280, 3840, 3840, 416, -1504
202=0, 0, 90, 2656, 1280, 3840, 3840, 416, -1504
203=0, 0, 0, 2656, 1376, 3840, 3840, 416, -1504
204=0, 0, 90, 2752, 1376, 3840, 3840, 416, -1504
205=0, 0, 0, 2752, 1472, 3840, 3840, 416, -1504
206=0, 0, 90, 2848, 1472, 3840, 3840, 416, -1504
207=0, 0, 0, 2848, 1568, 3840, 3840, 416, -1504
208=0, 0, 90, 2944, 1568, 3840, 3840, 416, -1504
209=0, 0, 0, 2944, 1664, 3840, 3840, 416, -1504
210=0, 0, 90, 3040, 1664, 3840, 3840, 416, -1504
211=0, 0, 0, 3040, 1760, 3840, 3840, 416, -1504
212=0, 0, 90, 3136, 1760, 3840, 3840, 416, -1504
213=0, 0, 0, 3136, 1856, 3840, 3840, 416, -1504
214=0, 0, 90, 3232, 1856, 3840, 3840, 416, -1504
215=0, 0, 0, 3232, 1952, 3840, 3840, 416, -1504
216=0, 0, 90, 3328, 1952, 3840, 3840, 416, -1504
217=0, 0, 0, 3328, 2048, 3840, 3840, 416, -1504
218=0, 0, 90, 3424, 2048, 3840, 3840, 416, -1504
219=0, 0, 0, 3424, 2144, 3840, 3840, 416, -1504
220=0, 0, 90, 3520, 2144, 3840, 3840, 416, -1504
221=0, 0, 0, 3520, 2240, 3840, 3840, 416, -1504
222=0, 0, 90, 3616, 2240, 3840, 3840, 416, -1504
223=0, 0, 0, 3616, 2336, 3840, 3840, 416, -1504
224=0, 0, 90, 3712, 2336, 3840, 3840, 416, -1504
225=0, 0, 0, 3712, 2432, 3840, 3840, 416, -1504
226=0, 0, 90, 3808, 2432, 3840, 3840, 416, -1504
227=0, 0, 0, 3808, 2528, 3840, 3840, 416, -1504
228=0, 0, 90, 3904, 2528, 3840, 3840, 416, -1504
229=0, 0, 0, 3904, 2624, 3840, 3840, 416, -1504
230=0, 0, 90, 4000, 2624, 3840, 3840, 416, -1504
231=0, 0, 0, 4000, 2720, 3840, 3840, 416, -1504
232=0, 0, 90, 4096, 2720, 3840, 3840, 416, -1504
233=0, 0, 0, 4096, 2816, 3840, 3840, 416, -1504
234=0, 0, 90, 4192, 2816, 3840, 3840, 416, -1504
235=0, 0, 0, 4192, 2912, 3840, 3840, 416, -1504
236=0, 0, 90, 4288, 2912, 3840, 3840, 416, -1504
237=0, 0, 0, 4288, 3008, 3840, 3840, 416, -1504
238=0, 0, 90, 4384, 3008, 3840, 3840, 416, -1504
239=0, 0, 0, 4384, 3104, 3840, 3840, 416, -1504
240=0, 0, 90, 4480, 3104, 3840, 3840, 416, -1504
241=0, 0, 0, 960, -960, 3840, 3840, 416, -1504
242=0, 0, 90, 1056, -960, 3840, 3840, 416, -1504
243=0, 0, 0, 1056, -864, 3840, 3840, 416, -1504
244=0, 0, 90, 1152, -864, 3840, 3840, 416, -1504
245=0, 0, 0, 1152, -768, 3840, 3840, 416, -1504
246=0, 0, 90, 1248, -768, 3840, 3840, 416, -1504
247=0, 0, 0, 1248, -672, 3840, 3840, 416, -1504
248=0, 0, 90, 1344, -672, 3840, 3840, 416, -1504
249=0, 0, 0, 1344, -576, 3840, 3840, 416, -1504
250=0, 0, 90, 1440, -576, 3840, 3840, 416, -1504
251=0, 0, 0, 1440, -480, 3840, 3840, 416, -1504
252=0, 0, 90, 1536, -480, 3840, 3840, 416, -1504
253=0, 0, 0, 1536, -384, 3840, 3840, 416, -1504
254=0, 0, 90, 1632, -384, 3840, 3840, 416, -1504
255=0, 0, 0, 1632, -288, 3840, 3840, 416, -1504
256=0, 0, 90, 1728, -288, 3840, 3840, 416, -1504
257=0, 0, 0, 1728, -192, 3840, 3840, 416, -1504
258=0, 0, 90, 1824, -192, 3840, 3840, 416, -1504
259=0, 0, 0, 1824, -96, 3840, 3840, 416, -1504
260=0, 0, 90, 1920, -96, 3840, 3840, 416, -1504
261=0, 0, 0, 1920, 0, 3840, 3840, 416, -1504
262=0, 0, 90, 2016, 0, 3840, 3840, 416, -1504
263=0, 0, 0, 2016, 96, 3840, 3840, 416, -1504
264=0, 0, 90, 2112, 96, 3840, 3840, 416, -1504
265=0, 0, 0, 2112, 192, 3840, 3840, 416, -1504
266=0, 0, 90, 2208, 192, 3840, 3840, 416, -1504
267=0, 0, 0, 2208, 288, 3840, 3840, 416, -1504
268=0, 0, 90, 2304, 288, 3840, 3840, 416, -1504
269=0, 0, 0, 2304, 384, 3840, 3840, 416, -1504
270=0, 0, 90, 2400, 384, 3840, 3840, 416, -1504
271=0, 0, 0, 2400, 480, 3840, 3840, 416, -1504
272=0, 0, 90, 2496, 480, 3840, 3840, 416, -1504
273=0, 0, 0, 2496, 576, 3840, 3840, 416, -1504
274=0, 0, 90, 2592, 576, 3840, 3840, 416, -1504
275=0, 0, 0, 2592, 672, 3840, 3840, 416, -1504
276=0, 0, 90, 2688, 672, 3840, 3840, 416, -1504
277=0, 0, 0, 2688, 768, 3840, 3840, 416, -1504
278=0, 0, 90, 2784, 768, 3840, 3840, 416, -1504
279=0, 0, 0, 2784, 864, 3840, 3840, 416, -1504
280=0, 0, 90, 2880, 864, 3840, 3840, 416, -1504
281=0, 0, 0, 2880, 960, 3840, 3840, 416, -1504
282=0, 0, 90, 2976, 960, 3840, 3840, 416, -1504
283=0, 0, 0, 2976, 1056, 3840, 3840, 416, -1504
284=0, 0, 90, 3072, 1056, 3840, 3840, 416, -1504
285=0, 0, 0, 3072, 1152, 3840, 3840, 416, -1504
286=0, 0, 90, 3168, 1152, 3840, 3840, 416, -1504
287=0, 0, 0, 3168, 1248, 3840, 3840, 416, -1504
288=0, 0, 90, 3264, 1258, 3840, 3840, 416, -1504
289=0, 0, 0, 3264, 1344, 3840, 3840, 416, -1504
290=0, 0, 90, 3360, 1344, 3840, 3840, 416, -1504
291=0, 0, 0, 3360, 1440, 3840, 3840, 416, -1504
292=0, 0, 90, 3456, 1440, 3840, 3840, 416, -1504
293=0, 0, 0, 3456, 1536, 3840, 3840, 416, -1504
294=0, 0, 90, 3552, 1536, 3840, 3840, 416, -1504
295=0, 0, 0, 3552, 1632, 3840, 3840, 416, -1504
296=0, 0, 90, 3648, 1632, 3840, 3840, 416, -1504
297=0, 0, 0, 3648, 1728, 3840, 3840, 416, -1504
298=0, 0, 90, 3744, 1728, 3840, 3840, 416, -1504
299=0, 0, 0, 3744, 1824, 3840, 3840, 416, -1504
300=0, 0, 90, 3840, 1824, 3840, 3840, 416, -1504
301=0, 0, 0, 3840, 1920, 3840, 3840, 416, -1504
302=0, 0, 90, 3936, 1920, 3840, 3840, 416, -1504
303=0, 0, 0, 3936, 2016, 3840, 3840, 416, -1504
304=0, 0, 90, 4032, 2016, 3840, 3840, 416, -1504
305=0, 0, 0, 4032, 2112, 3840, 3840, 416, -1504
306=0, 0, 90, 4128, 2112, 3840, 3840, 416, -1504
307=0, 0, 0, 4128, 2208, 3840, 3840, 416, -1504
308=0, 0, 90, 4224, 2208, 3840, 3840, 416, -1504
309=0, 0, 0, 4224, 2304, 3840, 3840, 416, -1504
310=0, 0, 90, 4320, 2304, 3840, 3840, 416, -1504
311=0, 0, 0, 4320, 2400, 3840, 3840, 416, -1504
312=0, 0, 90, 4416, 2400, 3840, 3840, 416, -1504
313=0, 0, 0, 4416, 2496, 3840, 3840, 416, -1504
314=0, 0, 90, 4512, 2496, 3840, 3840, 416, -1504
315=0, 0, 0, 4512, 2592, 3840, 3840, 416, -1504
316=0, 0, 90, 4608, 2592, 3840, 3840, 416, -1504
317=0, 0, 0, 4608, 2688, 3840, 3840, 416, -1504
318=0, 0, 90, 4704, 2688, 3840, 3840, 416, -1504
319=0, 0, 0, 4704, 2784, 3840, 3840, 416, -1504
320=0, 0, 90, 4800, 2784, 3840, 3840, 416, -1504
Neil Blanchard likes this
I posted that code per Neil's suggestion. I was a bit hesitant to do that since the file is a large one for a straight text list.
Herringbone is one of those patterns where there are a lot of entities in the pattern between any two similar entities and especially so for king size brick.
Woody
Woody
Thanks, Woody! Life just got easier!
ORWoody wrote:I get a message that the dhp extension is not allowed.FYI: You can always 'zip up' the file(s) you want to upload when the extension is not explicitly allowed.
Users browsing this forum: No registered users and 43 guests
