#75547 by Tony Goode
Mon Jan 21, 2019 4:42 am
I have created 5 GoTo views
When I recall them using the icon on the toolbar they do not appear
The screen does move to the area of the selected view but the layers do not switch on
The layers of my previous activity remain active
If I select the view from the floating layer manager the view does appear
I have purged the drawing
Any ideas would be appreciated
#75553 by Mark Bell
Mon Jan 21, 2019 3:53 pm
Hello Tony,
Have you tried using F2 Goto Views in the Utility menu as another option? If you're able to access them from the LM, try turning on/off the correct layers and updating one of the views then trying again using the icon toolbar to see whether than works. On rare occasions I've had the GTV's 'forget' their settings as you describe and have had to rebuild them.
#75597 by Tony Goode
Mon Jan 28, 2019 11:41 am
Mark
Thank you for your reply
I have tried what you suggest but to no avail
This only happens with this one drawing all others work as they should
So I have decided to just live with it until this project is complete.
Regards
Tony
#75599 by joshhuggins
Mon Jan 28, 2019 11:44 am
In the GTV menu, make sure S4 Layer Control is turned on. (Edited)
Users browsing this forum: No registered users and 127 guests
