Lars wrote:Why do pre-existing object colors not update when the objects layer color is changed in layer manager? Seems this should be a basic feature?
Thanks!
Hi Lars. You can actually get the objects to update colors by using the "Move" Command. Select the layer you want to "move" to, which in this case would be the same layer. Once you select the layer, you will see the "layer color" option (at S2) to toggle. Once you complete the operation, the entities will change colors. Not quite "automatic" as it requires a few more clicks, but it will work to update the entities colors.
Edit: Wanted to add that there isn't really any advantage of doing this as you still have to pick the entities, either individually or using the "mask" command or "grouping" the entities.
