I think the best way is to do it as a horizontal slab, and then tilt it up? You can also do a covered polyline horizontally, and then make it a symbol, and rotate / tilt it into position.
Specialty Windows
You can put specialty windows in Smart Walls by modeling the window and including it as a symbol in the Window Type definition.
I've attached a zipped-up AEC file of this example. For sloped walls like gable ends, you'll have to model the wall as either a 3D polygon, slab, or covered polyline (see my next post).
Neil Blanchard likes this
Specialty Windows Example Drawing
(19.99 KiB) Downloaded 516 times
Circle Top In Gable
In this example, the gables are modeled with covered polylines. The circle top windows are smart windows with a custom symbol.
Circle Top In Gable Example Drawing
(71.44 KiB) Downloaded 519 times
Thanks! - Josh
joshhuggins wrote:
...you did have to clip out the opening in the polyline via void or something right? The smart window didn't knock out the hole for itself?
MM wrote: 'Correct. The 'gable' polyline contains a 'void' polyline for the window opening.'
A big wish list item here would be the ability to add a vertex to a smart wall (ie. a wall with 5 points), allowing the fifth point to be placed at a higher z-h to create the gabled wall. This ability would really enhance smart walls and save a lot of time in currently having to model two separate entities to create the gable wall. ... nice examples too!
joshhuggins likes this
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
thanks every one for responding I appreciate it
Users browsing this forum: No registered users and 79 guests
