#76147 by Gravey01
Sun Mar 31, 2019 8:42 pm
I am having trouble with snapping accuracy. I have change the interface setting to object snap but it immediately reverts back to general. Any ideas ?
#76151 by Neil Blanchard
Mon Apr 01, 2019 7:39 am
Welcome to the forum!
Once you set the snap criteria, they stick. I recommend selecting only the settings you use - end point, intersection at a minimum, and then add the others you need.
Make sure you have Virtual and Offset turned off, as these are the easiest to misinterpret. Perpendicular is sometimes problematic, though once you get used to it, it can be very helpful.
Can you give a little more detail of what you are seeing?
Users browsing this forum: No registered users and 13 guests
