Can an edge of a void align with an edge of a master slab/polygon. Or do I need to add vertices's to an edge of a slab/polygon
The latter is the way to go.
I recommend using Covered Polylines, and voids can be coincident, overlapping, or completely outside of the master boundary. You can also put a 'notch' in one edge of the master boundary instead of making the void coincident with it.
Just be aware that if you use DataCAD to get the area (or perimeter or volume) of a polyline with overlapping or outside voids the result may not be what you expect:
DataCAD will simply subtract the area (or volume) of the void from the area of the main polyline even if the void is not completely within the main polyline (or add the perimeter of the void to the perimeter of the main polyline even some of the edges of the void are coincident or outside of the main polyline).
David Henderson
dhSoftware - Add-on Macros for DataCAD
Users browsing this forum: Google [Bot] and 56 guests
