Hi out there, is anyone having problems with the section function in the 3D edit menu . i created a 3D model using slabs and when i do a section sometimes only the horizontal slabs show up and not the vertical slab entities, this happened shortly after i accidentally hit the 3D knife tool instead of begin in the menu.
Is the section function supposed to work with smart enterties, i recall it had problems as well when i tried.
while we are at it can anyone tell me what the fold settings button does in the options drop down box.
thanks cheers using version 21 latest
