#76672 by Neil Blanchard
Fri Jul 12, 2019 7:50 am
Hi David,
We are starting a new project of apartment units, and I am using Spaces to do some footprint studies.
Can I set the color of the text separate from the outline / active color?
The Category label doesn't "remember" what I used previously.
#76688 by Neil Blanchard
Mon Jul 15, 2019 7:29 am
Thank you David. I added the categories I need using the Settings dialog.
Is there a way to count the number of each space type? In other words, I have 9 apartment units, and I would like to count them - is this what the reports do?
When I Copy a space that I created by Group, the label is not copying.
#76702 by Mark Bell
Tue Jul 16, 2019 5:21 am
Hello David,
Some summary points below:
1. The pop-up menu's are all to the left side of the screen - maybe set the default in the centre of screen? and/or, remember last position?
2. Have you considered a contour search for smart walls?
3. I had the drawing freeze when using Room Contour on an open sided 3-line shape - see screenshot below. The cyan are dots that extended along the bottom selected line in both directions:
Users browsing this forum: No registered users and 38 guests
