#76912 by seasdes
Mon Aug 26, 2019 8:57 pm
I created a custom line type that is simply two solid lines separated by a text. The line created ok. However, the spacing is less than the objects used to create the custom line type.
Is there a way to create the custom line with the same spacing as the objects used to create the custom line type?
#76914 by Mark Bell
Tue Aug 27, 2019 7:34 pm
Just a suggestion, have you tried knockout on the text as you can adjust the x-factor to knockout the line work? The other option is to increase the gap in the source graphics to get it closer to the output line type?
#76918 by joshhuggins
Wed Aug 28, 2019 12:30 am
Couple things to try depending on what you want exactly.
- You can try changing the spacing factor when you are creating the linetype
- reduce or enlarge your source
#76919 by seasdes
Wed Aug 28, 2019 5:14 am
Thanks Mark & Josh
Looks like adjusting the scale factor after drawing with the line is the easiest way to go at present till I figure out the scaling when creating the custom line type.
Users browsing this forum: Google [Bot] and 43 guests
