I seem to have lost the menu bar at the very bottom of the DataCad screen that showed coordinate numbers, and other information. I don't know what I did to make it disappear and I don't know what it was called. And I don't know how to get it back. Is there a default screen shot of DataCad that shows a full screen that one can view to know what all the menu bars are and what it was called? Then, how do I get it back. Thanks, much appreciated.
I now see that the name of the menu bar is called Coordinates/Hints Toolbar that can be turned on in the View/Toolbars dropdown menu. It would still be nice having a diagram of the full screen calling out each item (menu). Thanks.
If you go to the Help pulldown menu across the top, then open the Reference Manual there are screenshots and explanations on various menu/tool bars. You can also go to the Tools pulldown menu and open the Config Menu and pick the Toolbars tab to see what's available.
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Users browsing this forum: Google [Bot] and 115 guests
