#77466 by Roger D
Wed Jan 15, 2020 10:52 am
Is there a setting for when exporting to a .dwg, that all knockout attributes are removed from all polylines, even within symbol definitions.
#77468 by Mark Bell
Wed Jan 15, 2020 6:21 pm
Try the View pulldown/Knockouts then untick all the 3 options. Generally, ticking Compatibility Mode displays KO's in exported DWG's.
#77469 by Mark Bell
Wed Jan 15, 2020 6:24 pm
The other method could be to use Change/More/KO/NO, right click twice to go back to the Change menu then using EGAFM select the whole drawing to export, then exit the drawing without saving or pick undo to restore the KO's.
#77470 by Roger D
Wed Jan 15, 2020 7:19 pm
I could do that, but I don't think that would get rid of the old within the symbols where most exist.
#77471 by Mark Bell
Wed Jan 15, 2020 8:48 pm
You may need to Edit each symbol and remove then that way...or consider asking the recipient to turn off KO's at their end so they don't display on the software they're using?
Users browsing this forum: No registered users and 41 guests
