I am curious to know if you tried modelo or a similar service? If so, which one? Do such service add value to your overall architectural workflow?
https://modelo.io/
Thank you!
https://modelo.io/
Thank you!
you can get shadows on a given plane in the form of editable entities in DataCAD and can also be exported as Dxf/Dwg
It will also work with all entities including Smart Entities.
There are probably at least a few people who would very much appreciate that extra functionality that I am currently unable to provide.
Mark Bell wrote:Hi Prasad,
Some other ideas if you're looking for something more independent:
1. Create a web-based viewer and/or an Adobe Reader viewer, of DataCAD 3D files (AEC or other existing export format?) allowing offices to email clients/contractors/consultants models for direct viewing inside their web browser or AR without the need to install specific software. Perhaps a cross between O2C and Sunshader comes to mind or there may already be something out there you can use and build on? DataCAD released a VRML Viewer years ago which showed a lot of promise and seemed ahead of its time so maybe this could be a starting point?
2. The browser/viewer would need to show 2D PDF or raster images/drawings as well as 3D models or part models allowing easy transfer of key design information to site or meetings perhaps through each office/user's cloud-based account for remote access? This would also allow tablets and even smart phones to be used.
There's lots of possibilities.
Users browsing this forum: Google [Bot] and 55 guests
