When bringing an x-ref into a drawing the text and or arrows are not the same as what is on the original drawing although the text aspect ratio and the x and y distances seem to to be correct. The arrow leader to the left of the text appears correctly while the arrow leader on the left appears foreshortened and the appearance of the text in regards to the aspect ratio seems to be foreshortened from that on the original drawing. Removing fit text does not fix the problem. If I bring the drawing in as a self xref on the original drawing it shows correctly but not if brought into another drawing. What can I do to correct this?
Not quite sure I quite follow you on this one, can you upload a couple of screenshots of a before and after? Might be able to give you a better list of things to check.
The issue was apparently in the drawing. Text appearance would be different irregardless of whether it was text or a symbol. I tried purging un-used symbols, layering it out and repairing it neither of those solutions worked. I ended up moving everything to a new layer and saving that layer. I then created a new drawing with new layers moving things to their appropriate layers and made new views. Once I did that the text on the xref and symbol file worked as they should.
