#77915 by stephen11962
Thu Apr 23, 2020 5:16 pm
I am retired but once in a while I come back to do a little drawing.
If I go to inserting a different line type and try to evoke the Line Type Manager (Alt-L) or press the line type button in the menu area, a blank box appears with nothing on it. I can only make it disappear by typing Alt-F4. I checked the Program Preferences to see the Path Name Descriptions and it point to the correct folder. How to I populate the menu and line types available. I can see lines (by name) in the Status Panel by clicking on the down arrow.
I must be missing something but cannot determine what it is. Help!
Thanks
Stephen
#77916 by joshhuggins
Thu Apr 23, 2020 5:46 pm
Do you have the latest update for v17 installed?
#77923 by Neil Blanchard
Fri Apr 24, 2020 10:47 am
Hi Stephen,
stephen11962 wrote:I am retired but once in a while I come back to do a little drawing.
Thanks
Stephen
Alt-L is a custom keyboard macro - you may need to edit your DcadWIN.MCR file, to get it to work as you are used to.
If you look at Edit / Line Type/ - what do you see?
#77924 by stephen11962
Fri Apr 24, 2020 1:15 pm
Here you go:
L^15#^
//line type menu
;L^;^F9^S1^ 2020-01-07 changed to Linetype sbove
;Trim intersecting walls
It has been about 12 years since I mucked around here, but what I understand is that the ; does not interact with the macro but allows comments. And it seems that I did at one time do something, but I have earlier copies of dcadwin.mcr which have the correct,operable line L^15#^ . But I am now an amateur.
Having said all that, I do need help.
Thanks
S
#77925 by joshhuggins
Fri Apr 24, 2020 1:52 pm
Try replacing
L^15#^
with
L^;^S7^S8^
#77926 by stephen11962
Fri Apr 24, 2020 2:33 pm
Yes it is back, MAGIC, BUT, always that: When I exit the line type manger it does disappear but reverts to the empty box with not text, no nothing AND I have to Alt-F to get out of that.
Something still amiss.
S
#77927 by joshhuggins
Fri Apr 24, 2020 3:13 pm
Maybe try re-running the v17 installer and then selecting repair. Something may have become corrupted with your install.
https://www.datacad.com/download/dataca ... AD_17.html
#77928 by stephen11962
Fri Apr 24, 2020 4:27 pm
Did Repair, same behavior. But I can get the blank box to disappear from the screen by Shift-F4 but then it reappears if I right click with the cursor in drawing area. Alt-L will recall the Line Type Manager only to repeat the behavior. I think i am going to let this go. Is not critical to what I have to do now - unless someone has the answer.
But thanks all for the input!
S
#77948 by stephen11962
Sun Apr 26, 2020 11:50 am
More Line stuff: Now I find that the solid line draws like a dashed line, sometimes, but it identifies as a Solid Line. It does not increase or decrease in size by zooming in or out. This is happening in a drawing in which I have real solid lines. If I Alt-I on that 'real' line and then draw lines the lines are solid. I can copy and paste either 'type of solid line' and the copy is true to the line copied. I do not know if there are other problems.
I do not know what is going on or how this all happened. I wonder if it would be less time-consuming to reload the program from scratch? But I fear importing my customization will import the 'corruption' as well?
Anyone have any ideas?
TIA
S
#77949 by Mark F. Madura
Sun Apr 26, 2020 12:00 pm
Sounds like you've applied a dashed Pen Style to the line (not a dashed Line Type). If you double-click on the line to display the Entity Properties Editor, you'll see dropdowns for Line Type and Pen Style. What do they indicate? In the Change, More... menu, you can use the Pen Style option to change the entities you select to a solid pen style.
Note: Pen Styles are scale-independent which is why the dashes are always displayed and printed the same length.
#77951 by stephen11962
Sun Apr 26, 2020 3:20 pm
Mr Madura himself and Sunday!!
It seems that I have done what you said, but by mistake and out of ignorance. It has been a while since I have used DataCad but even when it was a daily event I had never used this feature. See what I did not know and have missed! I have also learned that what the suffix R and S mean, which puzzled me for a moment.
Even if I did not use all the features of DataCad I still consider it one of the unique and quality software programs I have encountered. Much thanks and appreciation.
Stephen
Users browsing this forum: No registered users and 104 guests
